Question about RCA EZ101 HD Camcorder
EZ101 gets "unknown usb device" error.
Have XP w/SP2 fully updated. Bought unit new,has had "tlc",not a scratch on
it. Problem started about 6 mo.ago. The program would load 10% of the
vids & completely lock up. (pgm.not responding). I found the EZ101 Restore
utility,that fixed the problem,several times. Now I get the "unknown usb
device" error,& the restore utility displays "no supported devices detected".
Looked at the device instance id & get "USB\VID_0000&PID_0000\4&2769D
55C&0&2". It does the same thing on another pc,but with a different instance
ID. ????? Is there any fix ? PC does not see it as a camcorder.
Any help would be appreciated.
Thanks in advance,Bob.
SOURCE: not installing drivers
same problem pls help
Posted on Dec 30, 2007
SOURCE: EZ201 Rca Small Wonder Camcorder
It isn’t your computer: this camera (although it is otherwise great) has serious interface issues with computers. Mine is driving me crazy and I am in South America, so all I can do is rely on these tech forums to try to get some clues. When I connect my camera to my computer, sometimes the computer sees it and it transfer files and edits just fine. Other times it sees and transfers, but then the software wont edit (says there is an error). Other times it sees it but the computer says it doesn’t recognize the device, and the software therefore wont run to upload the files. However, if I leave it plugged in long enough, *sometimes* like an hour later, it just all of a sudden recognizes it – but sometimes it never does, all day long. Sometimes I plug it in and it doesn’t show up on any drive at all, even if I change it from one USB port to another. There is a newer laptop here running Vista that never once has been able to see the camera, and an older one running XP that sees it every single time, but suffers a power surge because it is too old and tells me to unplug the device and reset the port and not to use it there again. When I can get my computer to recognize it, I immediately run the upgrade available on the site http://www.mysmallwonder.com/support/downloads.aspx and that usually fixes the problem for a few days – the computer can see the camera and recognize it for a few days – until it cant again! (Make sure to follow the instructions all the way through, which include disconnecting the camera from the computer and pressing the delete button on the camera after the download, and then turning the camera on again to finish the process.) The upgrade usually also fixes the software glitches (for when the computer recognizes it and I can upload videos, but not edit them, but today for example, the upgrade hasn’t fixed the glitches and I cannot edit at all. I am going to try deleting the RCA memory manager program and uploading again through the camera. One big problem I have is that I don’t have the original disk with me, so when the software goes psycho I have to download the program through the online upgrade that only will work when it interfaces with the plugged in camera – which depending on the day, may or may not be recognized by my computer, or even APPEAR on any drive. That’s where I am. Please let me know if anyone knows how to solve this.
Posted on Jul 06, 2008
SOURCE: My RCA M4208RD-B not detect the PC and need firmware updater
This link below is for the EasyRip Installer software itself.
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2253
This link is for the firmware updater for EasyRip software.
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/popup_adp.php?p_sid=undefined&p_lva=undefined&p_li=undefined&p_faqid=2245&p_created=1214240123&p_sp=undefined
See if this helps any. It appears that there are various problems with these players & it takes some "finess" to get them working properly. Even after the above software & updates, I am still banging my head on the wall. Good luck!!!
Posted on Dec 29, 2008
SOURCE: RCA RT2870 USB won't allow playlists or let me skip folders
I have this same system and it looks like the USB playback is lacking this feature, of switching folders. A workaround is to use shuffle play to jump to one of the last songs in the first folder, then turn off shuffle and skip forward a few songs until you get into the next folder....and so on. Not very good, but for this price I was glad to have USB playback.
Some generic MP3 players will work in the USB port, but they play exactly the same as a USB drive. SO no real solution for this.
Posted on Aug 02, 2009
pabloloco
  • 2335 Answers
SOURCE: computer not recongize the rca th1602 mp3 player
The first time I tried to restore the firmware in my Pearl it would not recognize it. I had to follow all the troubleshooting instructions that popup when you run the software. Basically, try taking the battery out and waiting 10 seconds or so. Run the software and read all the instructions at the bottom of the popup window. then hold the play button, plug your player in, and keep holding that button until the software recognizes it. It works.
Posted on Sep 18, 2009
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
My computer is not not recognising my card reader
update your BIOS. there might be new fix for your BIOS regarding USB...go to your manufacturers web site and download the BIOS update and install flash it to your BIOS
Mar 16, 2009 | Computers & Internet
Uknown device Error - Canon PIXMA M180 All-In-One
well i'm not sure but did u try to change the usb connection itself? or if it doesnt work try to chek if there are any windows errrors but most propably the connection
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
May 05, 2008 | Canon MP610 Photo All-In-One Printer
Labtec Wireless desktop 1200 not working- win xp sp2
Seen to be a problem with power manager.
On Linux the solution what
echo -1 >/sys/module/usbcore/parameters/autosuspend
I find it here:
http://www.linuxquestions.org/questions/linux-hardware-18/usb-error-usb-2-4-device-descriptor-read64-error-71-643022/
Apr 26, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Presario c508us unknown device on downgrade vista to xp
Downgrading to XP I take it? A Microsoft/Windows update should pick up the device if you manually initiate the update and choose "Custom" for type of update. You will see Hardware and Software updates in addition to the Critical/Security updates that are automatically installed and XP SP2 should/could pick up the device in question. You'll be provided the chance to add these additional updates before reviewing and installing them.
Good luck.
Feb 19, 2008 | HP Compaq Presario C508US 15.4" Widescreen...
Gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Jan 04, 2008 | Toshiba Gigabeat U202 MP3 Player
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all RCA EZ101 HD Camcorder Questions
RCA EZ101 HD Camcorder Logo
99 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
