Question about Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster
Russell Hobs 9206 toaster internal switch replacement
The spring wire inside my Russell Hobs 9206 toaster has snapped off the  switch mechanism. Do you know where I can get a replacement switch  and spring wire?
3 Suggested Answers
SOURCE: Need a replacement bakelite handle for our Russell
I will advice you check either or for the part needed for your device.
Take care.
Posted on Oct 20, 2010
  • 12223 Answers
SOURCE: Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
Posted on May 19, 2012
  • 32281 Answers
SOURCE: how to remove sliding knobs from russell hobs 9209-50 toaster
Usually sliding knobs are pulled off.
Posted on Apr 16, 2013
0 characters
1 Points
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
The left side of my toaster dosn't work
It's probably one of two things:1) They pressure contacts that engage the electromagnet may have burnt carbon deposits similar to spark plugs. One needs to clean in between the contact (two on each side) while putting slight pressure as the contacts meet.2) The spring mechanism that engages these contacts has snapped at the securing point, thus not able to put enough pressure to engage these contacts that power the electromagnet.
For some reason it's always the left side.
If the toaster is more than 5 years old I would suggest buying a new on , even though these toasters are very reliable. As the crumbs that left inside are so powdery and coats every surface inside, as well.
May 22, 2011 | Tefal TT744115 4Slice Toaster
The timer stops, the toaster keeps toasting, burning the toast.
The timer is also a electrical contact switch. When the timer goes to zero an internal spring force the electrical contact to open so the heating elements to stop heating.
So either the spring stuck so it can not open the contacts anymore or the electrical contacts have been stuck together by elctrical sparking during the on and off.
In any case you must replace the timer switch with a new one since they does not worth to anything else with it.
The operation does not need any profetional skills since it can be remove easyly by removing the bottom panel and be carefull to remove the wires conected to it with clips make some notes so you will put the wires in the same position of the new timer switch.
If you don't fill comfortable with above then let an electrician do it for you.
Good Luck
Apr 01, 2010 | Dualit Vario 20293 2-Slice Toaster
Require replacement wire which triggers the catch when the operating handle is pushed down. Where can I buy it?.
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
Sep 24, 2009 | Russell Hobbs 9206 Classic Coolwall...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Toasters
Russell Hobbs 9376 Classic 2-Slice Toaster
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
Dec 27, 2008 | Russell Hobbs 9376 Classic 2-Slice Toaster
Broken metal lever arm for 3/4 slice switch
Further to my post of an hour or so ago, I realised that 20 gauge is close to 0.8mm which is a standard size for Stainless Steel MIG welding wire.(Some MIG machines use 0.9 ) As I have some 0.8 I have now mended my toater in that respect and it works OK. It was easy to shape the wire which is not critical. It may not be quite so springy but its hard to tell the difference. I suspect 0.9mm MIG wire would be even better.
Unfortunately I have another problem. Hey ho.
Nov 03, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster Logo
50 people viewed this question
Top Russell Hobbs Toasters Experts
Mike Cairns
Mike Cairns
Dan Woods
Dan Woods
Are you a Russell Hobbs Toaster Expert? Answer questions, earn points and help others
