Question about Dishwashers
Hotpoint ultima DF32
Doesn't drain!
fills ok, washes ok, when opened water fills the base of the machine, obviously not draining as it should. Interior filter is clear - we've bailed out to check. No obvious blockage.
Is it repairable as diy?
is it worth repairing?
what's the likely cost for a call out? and
Does anyone know someone in the Cambridge area they could recommend?
  • Frances81 Jan 27, 2008
    All I can find is Hotpoint Ultima DF32. It was 2nd hand so I don't the original documents unfortunately.
  • 770 Answers
Please post the complete model number off the unit
Posted on Jan 27, 2008
Hotpoint wt960 machine does not drain the water
Your drain pump is out. Usually attached to your motor and operates when the drain cycle is engaged. It's usally a 20 dollar piece. good luck.
Apr 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt746 error f-12
Just had F-12 on my Hotpoint Aquarius washing machine. Problem was due to water not draining. Power off. My machine has access plate at bottom on the back. The water drain is held onto the drum via a jubilee clip and when i took it off the drain was clogged with hair, sweet wrappers, money, hair bobbles Once cleared, put back as was - machine now running ok..
Nov 03, 2008 | Washing Machines
Hotpoint ultima wf640
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marfked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight. Post back later if the code stil comes up...........
Mar 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima df32 dishwasher
I have had this problem with a dishwasher before it was the pump. some of the water was empting but that was the weight of the water pushing it down! if its still under garentee get someone out, I dont know how expensive pumps are! it may be easier to look on ebay fot a new one!
Mar 29, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
