Question about Motorola Mobility RAZR V3
Can't see screen outside in sun.
You can see the screen great inside but outside when its sunny you can forget it.
Is there anything I can do to help the viewing?
Thanks, Larry
  • hudson1323 May 20, 2009
    Cupping hands around doesn't work. I have the same frustrating problem.
    HELP!?
    Ziggy
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 111 Answers
Nope,they're designed that way..but when you're outside try covering the screen with your hands that might work great..
Posted on Jan 27, 2008
Inside condensation on my windows in my 2009 Volkswagen EOS
Normal at this time of year. You can buy a moisture kit from an auto parts store, or at a Walmart or similar type store. If you don't want to do that, wait till a sunny day and park the car in the sun with the windows cracked. It will help dry out the inside.
Jan 08, 2014 | 2008 Volkswagen Eos
How do i take picture of the moon
I assume you want a picture of the moon and don't particularly care what the sky looks like.
Consider a full moon. Just what are you taking a picture of? It's a landscape, right? Mountains, craters, etc. All under a bright midday sun without a cloud in the sky (the sky on the moon, not your sky). So what if the moon's a quarter of a million miles away from you, it's under the same sun. Yeah, it's a quarter of a million miles farther from the sun, but given the nearly one hundred million miles between the earth and the sun, the difference is negligible.
There's an old photography rule called the "Sunny-16 Rule." It says that the proper exposure under sunny conditions is f/16 at a shutter speed that is a reciprocal of the film's ISO rating. So, at ISO 200 the proper exposure would be f/16 at 1/200 second (or equivalent, such as f/11 at 1/400 second). You'll have to switch the camera to the Manual exposure mode to do this. Ignore anything the camera's light meter says.
Use this as a starting guideline. Take a picture and review it on the screen. Don't worry about the sky going pure black. You don't want the highlights to get blown out, or the moon will look like a white blob.
Feb 07, 2012 | Canon EOS 40D Digital SLR Camera Digital...
I have a Fuji XP 10..love it..but in the sun I cannot see a thing on the screen..the local camera shop has nothing..seems ridiculous to be unable to take pictures on a sunny day! Help
Hi, You can get anti glare screen protectors for phones that stick onto an LCD screen. I'd suggest picking up one of those and cutting it down to fit your camera's LCD, it's what I've done and it works great.
May 13, 2011 | Fuji Cameras
MC9090 being used outside in sunny conditions
If you are using Wavelink TE you can set the screen to different colours. That may help.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Sep 29, 2009 | Symbol MC9090 Barcode Scanner
Misreading outside temperature sensor on 2001 Audi A4
There are four sensors for ambient tempurature and they work in unison to provide information to the temp reading on the dash, the heater control head ( where to direct air, blending of warm/cold/outside/inside air flapper controls) depending on the ambient temp and the inside air temp sensor located just above the radio as well as the sun sensor on the top of the dash as well as the a/c compressor head.
When you start your car, the body control module takes the readings from all sensors, outside air temp located in front of the radiator, air temp sensor located in the airbox ( senses temp of air being drawn in from the outside into the air box), coolant temp, inside air temp sensor and the sun sensor on top of the dash (this is why it takes a few seconds for the climate control system to begine when you start the car). The intake air sensor is 1st priority, inside air second, coolant third, ambient 4th and sun 5th. For instance, if the sun sensor reads the sun is hot but the interior sensor reads cold, the inside akes priority. The goal is for the system to achieve a tempurature inside the car that matches the selected temp. It uses all of the sensors to set the system up to achieve that goal as quickly as possible.
Example; Its mid afternoon, sunny and 40 degrees outside adn your in stop and go traffic. The intake sensor reads 40 degrees, the outside sensor reads 60 degrees (heat from radiator...engine heat protrudes into cabin) and the sun sensor reads high (sun is strong). The system is set for 72. priority one sensor reads 40, inside sensor reads 65, ambient reads 60= system will blow hot air to the floor out put, dash outlets will lightly flow 65 degree air so the sun doesnt roast you yet your feet are cold(if it blew hot air from all outlets, your upper body would be hot but your legs/feet would be cold). as the interior sensor reaches desired temp, air will be distrubuted through thee dash, defrost and floor with the warmest air coming out the floor and defrost, coolest air out the dash vents. Its a complex system!
The two sensors that will screw the system up the most are the intake and interior sensors. the system will function reasonably well with just those two sensors though it wont blend air temps between outlets if the sun sensor isnt working. If the outside sensor fails, it simply uses the intake sensor, if the intake sensor fails it will rely on the front sensor. However, since the intake takes priority over the outside sensor, if the intake sensor sends incorrect resistance info rather than failing, it will take priority and cause the unit to malfunction such as in your case.
The intake air sensor can be changed from the outside with patience. If it where me, I would pay the two hrs labor and let the dealer do it right.
Kevin,
Kevins Small Engine service,
South Berwick ME. 03908
May 01, 2009 | 2001 Audi A4
Whiteout in viewfinder, LCD and playback when filming outdoors
You should check and see if your night shot is on. That would definitely make the screen go completely whit outside but work fine inside. Hope that helps.
Dec 21, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
No picture when its sunny outside colour is distorted inside its a jvc digital cam gr-d33ag
On several camera the ccd is sensitive to bright and causes the images to come out very dark or out of focus because the auto focus sensor is being blinded. Try taking pictures with you back towards the sun and try turning off your flash this some times helps out. I hope this helps you and happy photo taking.
Mar 28, 2008 | Cameras
Motorola Mobility RAZR V3 Logo
80 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
