Question about Compaq Evo N620c Notebook
When plugging in it starting by it'self got blank screen tried 2 or 3 of the suggestion here but none works i don't really know much about computers regards linda p.s using my sons computer know
    Scholar:
    New Friend:
  • 20 Answers
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
armania9
Posted on Jan 03, 2010
SOURCE:
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
Laptop displays blank screen - cannot see bios on bootup - power seems ok. checked ram - replaced each rack separately, still no joy.
This is a common problem with the dv2000, dv6000, & dv9000 models. It's because your video chip has partially come out of it's socket in the motherboard. This is not an easy fix unless you really know what you're doing, but if you did then you probably would already know about this problem and how to fix it. There are places that can fix the problem you have. The problem is finding the right place - one that REALLY knows their stuff. You could get your motherboard replaced with a new one that you purchase on ebay or have HP replace. Either way it's likely to cost you between $250 - $350 for the replacement of the motherboard. I would suggest selling your computer for parts to a repair shop. You should be able to get about $100 for it as-is. Take that money, plus the $250 - $350 you would have had to pay for repair and buy a new laptop. MADHATTER COMPUTERS
Mar 22, 2010 | HP Pavilion dv9000z Notebook
The screen turned white for about an hour, does not come on
try the reset first (little pin hole on the side) using a paper clip, hold it in for 10-15 seconds. if that fails, plug in your charger and charge for awhile the press and hold the power button for upto 15 seconds till it starts. it sounds like you might have multiple problems. the screen going white normally indicates a bad screen but might just need reseated (ribbon cable)..try what i suggested first, if none of those work, let me know and we will see what else we can do.
bill
Aug 18, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My screen doesnt work.
I suggest you to perform these steps.
Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. I suggest you to connect the notebook to external monitor and check whether its working or not. Then please perform the harddrive self test also.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
Montier is blank when i stat up
Your monitor should have a light on it that indicates if it has signal, if the light stays yellow(or blinks) as the computer boots it is not getting the signal from the pc. Check the VGA cable on the back of your computer, it a big blue connecter, it has to be unscrewed and and disconnect it to verify that none of the pins are bent, plug it back in snugly and see what happens.
Sep 16, 2007 | Computers & Internet
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Compaq Evo N620c Notebook Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
