Question about Sony STR-DE310
Sony STR-DE310 MY Sony STR-DE310 WONT WORK WHEN I CONNECT THE RED AND WHITE CABLES BUT I CAN HEAR THE RADIO A LITTLE BIT.
I am currently working on one of these that exibits the same behavior as the first post. You can hear a little bit, but not much. Eventually the fuse blows. I opened it up and the MP1620 MOSFET (mounted on the big heatsink, closest to the back) is open and has a big burn mark on the heatsink. There is also a burnt resistor in front of Q720, which is most likely the 5V supply for the FETs. I am a firm non-believer of anything Sony. That 90 day warranty that they give with most equipment (especially game systems) shows how much they stand behind their junk. Just my opinion.
Posted on Jun 09, 2008
Sdfsfsf
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
Posted on Apr 09, 2008
Str-de310 goes to protect mode with nothing hooked up to it except the power
Speaker positive and negative terminals are short circuited, carefully inspect the back speaker terminal if a small single strand of a wire causing this.
-SS
Oct 18, 2013 | Sony STR-DE310
How do you connect sony str-de 698 fm receiver to television, cable box and cd player
Connect it's two audio plugs, likely to be coloured red and white, to corresponding sockets on any device that has them and select that input on the device. You should then hear your tuner.
Depending on FM signal strength where you live you may need an aerial, some is always better than none.
Sep 21, 2011 | Sony STR-DE698 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Sony STR-DE310
Sony Receiver STR-DE310 flashing "PROTECT'
Replacing ouput transistors and probably a couple of resistors is best left up to a repair shop. The entire main board needs to be removed to access the solder side of the board, many screws and several connectors.
Jan 21, 2010 | Sony STR-DE310
My Sony STR-de310 is flashing "Protect", and none of the other buttons work. What does this mean>
there is a short circuit somewhere in the amp. turn it off and find/fix it before turning it back on again.
http://pdf.crse.com/manuals/3859380111.pdf
Jan 09, 2010 | Sony STR-DE310
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
Plugging an mp3 into a Sony STR-DE310 receiver
Yes U can.... just put the rca cable in the cd or tape/md receiver
Nov 10, 2007 | Sony STR-DE310
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
Sony STR-DE310 Logo
320 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
