LG Flatron L1718S LCD Monitor Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flatron out of range
Hi, i have just purchase a flatrun l1718s had cannot get it to work with my system, its out of range, how can i fix this??
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
0
Helped
215203
Points
1334
You need to have a freind bring you a different better monitor. then lower your settings for your display. then install your monitor.
Hi my LG L1718S monitor wont start from energy saving mode
I had the same problem with my monitor, the problem was that one of the "pins" or "prongs" was bent and mashed flat on the monitor's port plug in cable (the cord from the monitor that plugs into the computer's monitor port). I carefully pried up the prong and straightened it out the best I could and that fixed the problem for me.
1helpful
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
1helpful
Hi can my flatron L1718S monitor be connected to a sky box for use as a TV? thanks
You will need another box to convert the output signal from Sky box to VGA output to feed the monitor. Juts Google ' Video to VGA adapter'. For example:
http://www.thenerds.net/STARTECHCOM.StarTechcom_Composite_and_S_Video_to_VGA_Video_Converter.COMP2VGA.html?affid=8&productads=1
You may also need a good set of powered speakers for good sound.
Please leave rating if it helps.
When i turn my computer on the monitor flickers for a second then just goes black. at the start i can see the desktop but after that it goes black lg flatron l1718s
You may have problem in the power supply, common causes are the bad capacitors (bulging top/seal, or leaking). That will be the first place to check. I will assume that you have already try it with another PC and it still does not work. See pictures here for a guide so you know what to look for inside:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find so it will help out other people also.
3helpful
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
