Question about Pasquini Livia 90 Espresso Machine
All 3 lights on Livia lighting up with hot water use
When I use the hot water dispenser on my livia, all three lights blink together, as if the water resevoir is low (but water is full). In addition, it is just unpredictable. There is never one way to get it to work normally. Sometimes I need to turn it off and wait, then just turn it on and it is fine. Other times, it starts a brew cycle when I turn it on and the buttons are not "pushable". Instead I have to just turn the machine off. We have done cleaning cycles and checked the wire connection to the water resevoir.. any other tips before we spend a lot of money getting it serviced? We don't have a warranty, it was purched used. Thank you!
  • roby253 Sep 18, 2008
    It starts a brew cycle when I turn it on and the buttons are not "pushable". Instead I have to just turn the machine off. We have done cleaning cycles and checked the wire connection to the water resevoir..
  • Anonymous Dec 31, 2008
    I posted this originally almost a year ago. Sorry to say we wound up having to ship our machine from Ohio to California to have it fixed, about $45 each way, plus $25 for a box to ship it back, plus the cost of the repairs including a new CPU.
    I don't recommend purchasing this machine used, we spent more than new when we were finally finished. :( Good news is it works well now, but I wish we had started with new or another machine altogether.
  • 4 Answers
Is this a Livia 90 semi or auto ?? It sounds as if you are talking about an auto. The autos have had a history of the cpu controller board going out. Probably going to have to take it in for service for proper diagnostic repair. Parts are not cheap and with no warranty- you don't want to start throwing parts at it to get it working right.
Posted on Dec 31, 2008
Intermittent water flow and blinking lights
the water filter should be changed at least every 6 mos. when the filter is dirty it will not allow the water to flow at full force because it is restricted. change the filter and I think that will be the answer.
Apr 16, 2014 | Amana Refrigerators
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
My machine is actually a Bezzera Bz99 which seems to be exactly the same internally as Pasquini Livia 90. The problem is Machine turns on and both lights go on. After a few seconds, relay clicks and green...
I know this is an old post but I have the same issue and need to replace the transformer. How to get in touch with Tyler di Giovanni? Can't seem to find contact info ;(
Oct 27, 2013 | Pasquini Livia 90 Espresso Machine
2000 Buick Century - water pump replace
The water pump is not the problem if the recovery tank is full and no coolant is being sprayed onto the underside of the hood. the problem is a defective low coolant sensor which is very common in this car model and year. The sensor is in the radiator side tank and easy to replace as well as cheap, personally i disconnected mine.
Sep 03, 2012 | 2000 Buick Century
Hi- the espresso maker is acting up. The water tank is full, but the pressure won't some up and the 3 lights are blinking. After shutting it off and turning back on, it makes a noise for a few seconds and...
Hi
The first thing I would check is the line to the water tank. Is it on, is it grounded? Next I would add some tap water. If you use distilled or RO water the computer can't see it. There has to be minerals in the water for current to flow. I have a manual I wrote, I can send you if you email me.
Jan 20, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Jul 04, 2010 | Abernook Pasquini Livia 90 Semi Automatic
Followup question for bansheracer re: old Livia 90
Do you have any lights on?
Try removing the water tank's ground wire. Ground it to the frame at one of the grounding locations and see if the machine will respond. If it does then the water does not have enough mineral for the computer to see. Add some tap water.
Dec 27, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
351 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
