Question about Maytag MAH8700A Front Load Washer
Maytag mah8700A I am getting the code "ds" on my 2 yr old machine. It mentions it is something to do with the door switch. "Door switch is read as open and the door locked switch is read as locked" Any idea how to fix?? Thanks
  • Anonymous Feb 12, 2008
    "ds" is showing on the same exact maytag washer that I bought in 2005 brand new at Sears.
  • robert samples May 11, 2010
    first can you open the door when it reads locked second i need the serial number
  • 105 Answers
Ds - means that the door is open while the washer is running sometimes this can be easily fixed by opening the door then closing it and pushing it pretty firm to make sure it latches.
If that doesnt work there very well could be a problem that would need to be fixed by a service repairman you can call Maytag USA Customer Service @ (800)688-9900
hope that helps.
Posted on Jan 27, 2008
My front load washer is flashing DL. It is a maytag but I do not know the model number. I bought it about 2 years ago. I have it in my apartment and I think that it is 24" in width.
Hi There
I'm sending you this to read and hope this get's you in the right direction.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Maytag MAH8700A Front Load Washer
I keep getting error code od the door switch is stuck in. Is there anyway to pop it out?
Switch is probably broken! You probably have to change it! You can try to pry it open but be carefull!
Dec 06, 2009 | Maytag MAH8700A Front Load Washer
I have a maytag neptune model MAH5500B with a Lr code - what do I do!
The code L supposedly points to the door lock, see if the door lock loop is not bent or broken
Oct 28, 2009 | Maytag MAH8700A Front Load Washer
I am in the middle of a load of laundry and it has stopped and the error code reads "suds". I am unable to get the machine to work again. How do I fix this?
When the door finally unlocks run bleach and hot water through a load and then use only 2 Tablespoons of HE detergent. No matter what. You are either using too much soap or your not using HE detergent.
Aug 19, 2009 | Maytag MAH8700A Front Load Washer
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
Neptune replace door switch
It sounds like a door switch problem, I have seen where they break loose from mount and door pushes switch inside. or the switch my be faulty and showing open all the time. I think u can reach the switch through the top of the washer two screws in the back will allow the top to slide back and up to remove.
Jan 24, 2009 | Maytag MAH8700A Front Load Washer
Error code "sr"
Sr is a stuck relay on your main board.Replace your pc board.
Dec 30, 2007 | Maytag MAH8700A Front Load Washer
Washer
Sounds like you need to replace the door switch
Jun 23, 2007 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A
Joe, ds is a door lock malfunction. The door lock latch shows closed and the door switch shows open. Try this, unplug the unit for 60 seconds and see if the error comes back. If it does, with the power on press and hold the chime and xtra rinse pads together for 3 seconds. This will put it into the service mode. Once in the service mode press the chime button again to unlock and the temperature pad to lock. See if they operate. If still no luck you are going to have to do some tests on the door lock switch to see whats happening. You do have a 2 year warranty on these parts and being that it is only a year old, tell them to throw in the labor....Catriver...post back.
Dec 13, 2006 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
