Question about Samsung HT-DS610 System
Protection When ever I turn on my DVD player it will say DVD/CD but then it will say Protection and turn off.
  • 2 more comments
  • Ommy Apr 13, 2008
  • pjgolf Apr 30, 2008
    turn the system say hello, and proction and goes off. What is up?
    Pen1
  • papawjc Jan 28, 2009
    same thing; it says protection and shuts off
  • Anonymous Feb 11, 2009
    HOW DO I GET THE PROTECTION OFF???
My bro's unit did the same thing, took it turned it on held on/off button in for 10 seconds or so, it did the same thing by shutting down. turned it on with remote and quickly hit enter on remote and it began working, beginers luck i guess. dont know how long it will last.
Posted on Dec 01, 2008
    Genius:
  • 1,067 Answers
Doe sthis do it on all dvd or just 1 is fan out on it in well vented place
Posted on Jan 27, 2008
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
What's your problem?my toshiba dvd player has protection on and can't get it off
The protection circuit is sensing a load problem, a malfunctioning laser assembly or a failure in the audio/video processing circuitry, far cheaper to replace the DVD player.
Mar 10, 2012 | Toshiba Televison & Video
MY DRIVE HL-DT-ST DVDRAM GSA-4040B CAME WITH MY COMPUTER THAT I BOUGHT IN 2003. I HAVE NEVER TRIED BURNING DVDS UNTIL NOW. I HAVE CLONE DVD AND TRIED MAKING A COPY. IT ONLY PLAYS IT IN MY COMPUTER BUT NOT...
you just need nero program and know how to use if didn't work ,
note : the cd or dvd device when you didn't use for along time that cause to damaged
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | LG GSA 4040B (GSA-4040BI) DVD±RW...
I turned the DVD player off last night and this morning it will not turn on. Any thoughts, suggestions? I do have a DVD in the player that I need to get out somehow....
it is possible that the power supply unit in the DVD has failed. You will need to open and ccheck, the fuse might be open and if a new fuse blows out then the SMPS unit is faulty.
Possible that the Sm driver IC /driver has failed. Possible also for allied components to have failed.
Or else you can change with a new unit.
Helpful?
Aug 28, 2010 | Samsung DVD-V3500 DVD Player/VCR
My dvd/cd player gives me some kind of message when I turn on the power. I haven't used it in a couple of weeks. But I took out a cd to play in another room. When I came back to put the cd back into the...
what kind of CD/DVD-ROM are you using? Sometimes the CD are protected and cannot be played with every ROM. and also try playing another CD/DVD to study if it would do the same.About opening the CD/DVD-ROM if it is still not opening get an office-pin and push it into the small visible hole on the CD/DVD-ROM
Aug 02, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
I have burned a .wma video file on a cd-r, on my computer it runs perfectly... only when i put it in my dvd player it say's stop and won't play. Can someone help me out ? Thanks Jeff
Several causes for non-playback:
1. Your CD player doesn't like CD-R
2. Your CD player doesn't recognize wma
3. The music you converted to wma is copy protected and the CD player wont play due to that.
Solutions:
1. Most likely this isn't the problem as most working CD/DVD players recognize CD-R. Double check with your user manual.
2. Check your DVD player's playback formats. Most will play mp3 and wav. If that's the case, rip your music to mp3.
3. There are many hacks out there to remove copy protection. This you'll have to figure out on your own :)
May 02, 2009 | Philips Televison & Video
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
Pioneer XV-DV434 DVD/CD Player
unplug it from the wall for a while, if that don;t do it then it will have to be taken apart and checked for the reason
Oct 11, 2008 | Pioneer DV-350 DVD Player
Samsung HT-DS610 System Logo
279 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
