Question about Dishwashers
Dishwsher door When I open the door of the dishwasher - it won't stay down whilst I load it - it's driving me mad - help!!!!
  • 1 more comment
  • elaine57 Jan 27, 2008
    Hi
    Thanks for responding.
    It is Electrolux ESL 63010.
    The lower rack slides out on to it for loading and unloading. At the moment I have to hold the door down with my knee whilst loading etc but occasionally if I move the door shoots up and so do the pots!!! It just won't stay down and it's only a few months old.
  • Gary Davd
    Gary Davd May 11, 2010
    your springs may need adjusting is it a Miele or Asko /Bosch unit?
  • robert samples May 11, 2010
    give me your brand and model number and do you pull the lower rack out on it while you load it
    President:
  • 1,314 Answers
Hes right what can i say
Posted on Jan 27, 2008
  • 770 Answers
Notice the adjustment on the spring there is one on each side you will have to move it to the positon you need to adjust the tension..Hope that Fixed Ya..
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Door will not stay down when opened to load dishwasher
Sounds like the door springs need to adjusted to a lighter tension. Take off bottom panel(s) to access them.
Sep 26, 2011 | Dishwashers
Door is leaking at the bottom of the new dishwsher. Made sure it was level. Any other Suggestions
well if its new you should not touch it ,,the best thing to do is call for service because your under warranty,,there a 1-800 number on the inside lip when you open door..or check the back of your owners manual..if anyone srevices it it will void your warranty,,not worth it ....good luck
Sep 12, 2011 | Maytag Dishwasher
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
No water in dishwasher. When turned on all we hear is a clicking noise.
The problem you have here is the solenoid valve is either not opening or there is no water to the dishwsher. For more help check out this tip.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Feb 03, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Door will not stay down while loading
Please search for the sticker that is probably one the door (right side) that lists the model and serial number of your dishwasher. It is hard to provide specifics without this information.
But generally, the spring that is part of your door hinge has broken and will need to be replaced.
Please post back here with more info, OK?
May 04, 2009 | Dishwashers
Dishwashers Logo
187 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
