Question about Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier
Light on volume
When i frist got my Onkyo Tsr674s the light behind the volume button worked then it stopped is it in the wrong channel mod
    Novelist:
  • 130 Answers
The "light" is a LED (light emitting diode).
Typically does not burn out unless overly saturated [voltage/current].
Yes; check the two wires that go from the knob/led itself to the PCB [printed circuit board]. Should all be fine, check to see if you are getting voltage on the wires [~ 1.7VDC]. No Voltage? The transistor driver is to blame [usually small, black transistor].
Posted on Oct 15, 2008
    Scholar:
  • 146 Answers
The problem is most likely in the unit. You could have a burned out lite or just a bad connection to the lite. You can take off the volume knob by just pulling on it and checking it out thier, then take the top cover off and follow the wire from the knob and check out the connections.
Posted on Mar 15, 2008
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Hisense tv factory reset :
To do a factory reset; you should enter its service mode option. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mod entry, adjust and exit procedure to many popular brand TVs are given in detail.
Jan 23, 2014 | Televison & Video
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Stanby light for zone 3 is on , cant shut down the volume, i need to reset the receiver, any steps i have to follow?
To reset the Onkyo TX NR3007 AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. “Clear” will appear on the display and the AV receiver will enter Standby mode.
Thanks for using Fixya.
Good Luck and have a nice day.
May 27, 2010 | Onkyo TXNR3007 91 Channels Receiver
I have an Onkyo tx-sr605 7.1 channel receiver in which I have set up currently with only with 5.1 channel. The system sounds great, but I am finding that when I set the volume to a level to hear the...
After a long effort searching on Google, I found a solution. There is a Late night setting on the remote that limits the loud sounds scenes so it is not much loader than the dialog. Works great, I can't believe I never notice the button before.
Jan 20, 2010 | Onkyo TX-SR605 Receiver
Speaker volume settings
I figured out the problem.  After you set the individual channel volume for each speaker you need to push the test button on the remote and this will lock in the settings.  Thanks.
Oct 24, 2007 | Onkyo TX-DS575 Receiver
Right front channel sometimes does not work
you have dry solder joints in the output stages to the front channel.-solution. resolder channel.... or dirty speaker protection relay contacts. can be determined by tapping the top of the protection very gently when fault occurring. solution. burnish contacts and treat with crc2-26
Oct 20, 2007 | Onkyo TX-DS676 Receiver
Low volume while on both DVD and watching Satellite channels.
call onkyo product support 8002251946 option 6...since they did the mod for u...they should b able to take care of this at a minimal charge if any. alan audio video designs 3822 s. staples cc,tx 3618577236
Apr 30, 2007 | Onkyo TX-DS989 Receiver
Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier Logo
113 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
