Question about Baby Gear
Roger black treadmill.
Hi hope you can help.
I bought a roger black treadmill second hand about 6months ago and when i moved it i snapped part of the casing where the elictric cable goes in. it is a small plastic surround in the same shape as the connecter ,held in by two screws.I cant find a roger black repair site or parts site.
can you help?
  • 3 more comments
  • mick1965 Mar 31, 2008
    I have the same problem, i have recently bought a second hand roger black gold treadmill without the power lead and require a replacement lead plus possibly support to fit it.
  • pauline14 Jan 15, 2009
    I have a problem we moved our theadmill and standby light comes on but monitor does not work nor does the threadmill
  • Jax_bradley Mar 11, 2009
    Hi
    Wonder if anyone can help me......
    My son's friends were recently playing on my treadmill and somehow broke the red safety key which will no longer slot into position, hence the machine won't start.
    Can anyone advise me what to do???????
  • micky_bell Mar 29, 2009
    roger black gold treadmill - light on power switch, but no panel display, treadmill can move up/down, whats wrong??
  • micky_bell May 11, 2010
    I tried what spider box said & the wires were intact, however I will get the inline reset botton & switch checked out as they may be at fault, not the display panel...which is what I was focussing on!
I can repair or supply any roger black parts that you would need. contact me on 01706 371711
Posted on Oct 07, 2008
  • angelineguad Jul 31, 2011
    Can you supply me with a power cable for the Roger Black 2010 Gold Treadmill ?
Im after a safety key for e Roger Black treadmill. Cany anyone help ???
Thanks
Posted on Nov 30, 2009
What can i use to lubricate the bed of the running machine, and where can i get it.
Posted on Nov 15, 2008
If you havent a safety key, a piece of card cut to size will work. You might need to fold the card a few times to add thickness and just slot it in where the key should be.
Posted on Apr 25, 2010
I had the same problem, power light on but no display. I unscrewed the power unit from the side to discover that two wires had come lose, I popped them back in, screwed it together again and it works fine!
Posted on Apr 18, 2010
Hi I have misplaced my cable for my R Balck Gold treadmill !!! where will I get a replacement?
Many thanks
Posted on Mar 06, 2011
Hi im after a roger black safety key as i've lost mine
Posted on Feb 28, 2010
I bought roger black gold running machine red light came on but nothing worked after i moved it remove 2 screws on red light switch check wires when u pull out switch mine was off
Posted on Apr 02, 2009
Hi Every one,
I am treadmill seller in 'Nelson, Lancashire' I get supply of treadmills and many of them are faulty, I am looking for any electrician or expert who could do my jobs to repalir treadmills.
I get Roger Black, Pro Fitness, Reebok etc.
Can some one who could help me at reasonable charges send me your detail and i will ring you to discuss.
At the moment I have got 4 treadmills which need attention.
Thanks
Posted on Nov 21, 2009
  • love9994 Nov 21, 2009
    Hi Every one,
    Thanks
  • dutton05 Mar 01, 2011
    Hi do you Still Get Gym Equipment in i'm looking for A roger Black treadmill Lcd display
    dutton05@hotmail.com
The only place you can get spare parts is from them direct. technical support line is 0871 474 2614
Posted on May 09, 2008
I have a Roger Black Gold Medal Treadmill that I thought was powered but must be Motorized and done Twenty Two Mile runs on it and have moved the incline from 0 to 1% whilst actually running and belt moving. There is a horrid squeaking noise but apart from that all is well. How come it is squeaking?
Posted on Aug 21, 2013
I know you left this post 5 months ago, but are you still able to access spares? Im after all the screws for my RB Treadmill and am a bit stuck!! Hope you can help
Tory
Posted on Oct 28, 2008
  • Tory_28 Oct 28, 2008
    Tory
Hi, I moved the Roger Black treadmill to different room. IT stopped working , no power at all.
Take something like a clock, lamp, or radio that you know works and plug it into the same socket you have your treadmill plugged into. This will determine if you have power to the electrical outlet. If that is not it I have attached a video for how to do generic checks on any treadmill that does not have power.
Nov 16, 2017 | Exercise & Fitness
Roger Black JX 286 - is the distance on this treadmill measured in miles per hour or kilometres per hour?
Firstly look Via Google, for your needs, Ive found some info on the Argos website.
Dec 12, 2015 | Exercise & Fitness
How to fix a treadmill
see the video attached. lube the rollers bearing front +back.
However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS.
2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty.
God bless you
Oct 19, 2013 | Exercise & Fitness
Rogerblack gold treadmill wiring
see the diagrams attached. God bless you
Jul 14, 2013 | Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
I have a TX350 sportcraft treadmill, works great, but shocks our hands everytime we use it and we lost the user manual when we moved a few years ago. ?
I am not a fitness expert but I did want to pass along a few resources in case they may be useful. Here is a parts list for the TX350, and here you can search for treadmill repair companies in case you need to have someone in your area take a look at it. Hopefully you can find a solution without needing to spend money on repairs, though.
Mar 14, 2011 | Sport & Outdoor - Others
I'm trying to help my friend move her bedroom round as she has new wardrobes coming, and we cant get her roger black treadmill out of the room with out dismantling it, but she has lost the manual so I need...
I have a Roger Black Treadmill & it came in 1 piece ready to go. There is no way to dismantle the one I have. Not sure if there are multiple models but I have only ever seen 1
Aug 31, 2010 | Baby Gear
Roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Apr 30, 2009 | Exercise & Fitness
Lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Feb 01, 2009 | Exercise & Fitness
Open Questions:
I'm I dropped my necklace inside my 2018 Camry XSE & I finally saw it today a few weeks inside the lining of the drivers seat belt buckle. Can you tell me how to retrieve my necklace? Thanks! Denise My necklace is inside the lining around the "stem?" Of the seat belt buckle down inside a hole. It's a white gold necklace but appeared to me that it's laying on top of something silver? Possibly some type of track inside the assembly. Honestly I have no idea what I'm talking about. I was excited when I saw it since it appeared as though it could be easily retrieved and it doesn't look like it's very far down inside the lining of the buckle either, so since I have tiny hands I thought I might possibly even be able to get it out with only my hand. Sadly I was mistaken. Next I took some thick, heavy craft wire; first thing I thought of bent it over & made a hook on on end? I'm no fisherman but it seemed that logically it should work? I should be able to catch the chain in the hook. With the fabric of the lining being a charcoal color, inside the lining even darker. Inside a dark car with only an over head light, trying to hold a flashlight while necklace fishing in over 100 degree temps, though I'm stubborn and didn't want to. The heat did finally convince me I had no idea what I as doing and the chances of my catching my necklace at that point much less actually reeling it in safely were probably few and far between. So I'm back to searching the internet yet again. Ha! If you're wondering why I'm going to such lengths to retrieve a necklace, I bought it the day my first grand baby was born and it has her name and birth information engraved on it. It's the sentimental value for her DeDe that makes it so special and why I want to get it back so badly. I'm very much appreciative of anything you can advise me to do to help me with this process. Thank you so much, Denise Tallant a/k/a Stella James's DeDe
Sep 24, 2018 | Baby Gear
Baby Gear Logo
9,843 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
