Question about Maytag MMV4205 Microwave Oven
Dead Microwave Microwave went dead after using it to defrost. The lights and everything shut off and won't turn back on. 15 minutes after everything shut off we opened the microwave door to find the inside extremely hot.
  • Anonymous Mar 30, 2014
    the microwave turn on when the door is opened
    Sergeant:
  • 226 Answers
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Posted on Jan 27, 2008
  • 871 Answers
Hey
check this out.. this might help you.
http://www.repairfaq.org/sam/micfaq.htm
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Microwave went dead as soon as I started heating. Replaced its fuse:58001220
The klystron or the hi voltage transformer are faulty. The klystron is the part that generates the microwaves. The transformer supplies the voltage to operate the klystron.
Dec 31, 2014 | Microwave Ovens
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I inadvertently had the power on rather than the "kitchen timer"-about 10 minutes. I switched to the kt, but everything went dead within a minute. Did I kill it?
Wait an hour or so, it may come back on, there are thermostats inside, some of them are self-resetting, some are not. Good luck.
Dec 18, 2009 | Microwave Ovens
Dead microwave
You have likely blown the thermal fuse, its a small silver 1/2" pointy wire on each end and secured by clamp and normally brass crimps to the wires.
usually attached around the fan or motor area.
see this picture
http://chinafuse.en.alibaba.com/product/50391300/50098721/thermal_fuse/Thermal_Fuse/showimg.html
Jan 27, 2008 | Maytag MMV4205 Microwave Oven
Microwave completely dead
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Maytag MMV5165 Stainless Steel 1000 Watts...
Maytag MMV4205 Microwave Oven Logo
191 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
