Question about Hotpoint WMA76 Front Load Washer
WMA61 Hotpoint Washing Machine 'Red Tap' symbol is flashing
The troubleshooting guide for this problem says it means the machine can't fill., and to check water supply is turned on and hoses not kinked. Of course the water is on and the machine is indeed filling. If I press the start button the light goes out and the machine continues to overflow.
I have discovered that the problem lies around the water level switch. I can remove the plastic pipe, blow into the switch and hear the contacts operate and this stops the filling. The pipe is not blocked either I can blow through fairly easily. Tempted to purchase a new switch but don't want to waste my money. Any suggestions.?
  • aajones Jan 27, 2008
    Thanks, I'm going to try a new switch
    I decided to have one more look at the tub end. I removed the whole tub - don't know what the correct term is, contains a cone shaped insert with a ping pong ball shaped float - but anyway inside I found a fair collection of rubbish. There was coins buttons and allsorts of debris. Cleaned everthing and rebuilt, The machine is now fully working. Thanks for your support and amazing response.
    President:
  • 1,314 Answers
Well if your sure the other end is connected to the tub and is tight then id replace the switch its out of calibration it works off positive pressure from the water in the tub if you can blow in it and it actuates doesn't mean its working off the right pressure from the tub
Posted on Jan 27, 2008
  • robert samples Jan 27, 2008
    well let me know itl help others but thats your promblem
    hey you did the work bravo
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does lf code mean?
There is only a IE or 1E error code which indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Mar 25, 2016 | LG Washing Machines
Why does my machine make a loud humming noise after filling with water ?
It could be that one of the fill valves is stuck, or the fill hose is kinked, or that the water supply to the cold fill hose is blocked. If you have access, check that the external cold water isolating tap is ON and the supply to it, then confirm that the hose is not kinked. If your machine has been moved recently, perhaps for cleaning or decorating purposes, a kinked hose is the most likely cause.
Jan 09, 2018 | Washing Machines
Comes up 5 minutes after cycle starts, e10.
I don't see a brand listed for your washing machine. But an e10 error code can be due to a water supply issue. This is often the result of the water inlet screen being plugged, but it could be as simple as a kinked inlet hose. Check that the water supply to the washer is fully turned on and that all the hose connections are tight. Also make certain that the hoses are not kinked and are as straight as possible. Getting at the screens will probably mean disconnecting a hose and removing a cover. Once you get to the screen clean it out with a small screwdriver, toothpick, q-tip or other appropriately sized tool. Be careful when digging into the washer and always make sure the washer is unplugged when performing work.
Mar 02, 2011 | Washing Machines
Getting message LF.. what dose that mean
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Whirlpool WTW6400SW Cabrio Washer
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Lf code on washer.checked hoses and valve both ok unit will run after opening the lid and closing lid and pressing start again. takes 10/15 minutes for a load to start
LF means that it is taking too long to fill. (If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.)
Supply hoses could be kinked or clogged(some have screens in the end).
This could be a supply water pressure/flow problem. Make sure you have good water flow though the hoses to the machine. (Take off and try running into a bucket)
The water fill valve may be failing to open all the way or it could be clogged.
I hope this helps.
Mar 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint qualtis washing machine spin display showing H20 and won't start. model AQXXF 149PM
H20 means a problem with the water inlet supply.
Check the inlet hose/s for a kink or restriction, make sure it is turned on fully at the supply..
If it is cold fill only, could be a frozen pipe.
Hope this helps.
Jan 07, 2010 | Washing Machines
Cold water flow restricted on model LA8800AL
Check the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. (Especially the cold water side) Check the solenoids using a multimeter or ohmmeter and testing continuity. A lack of continuity will mean a bad solenoid. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Oct 02, 2009 | Washing Machines
Hotpoint WMA76 Front Load Washer Logo
659 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
