Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Filtered water not dispensing
I have 2 problems. I've turned the settings to it's lowest and the fridge is still very cold which led to freezing the filter and not allowing water to flow through. I adjusted the thermostat and seems to have helped but the water is still not flowing. I think something was damaged behind the filter when it froze. I've changed the filter but no water still.
  • Anonymous Jul 03, 2008
    Water stopped dispensing. Not sure where the filter is - am looking for this information.
    Per the suggested course of action, all of the sounds, etc. seem to me to indicate the electrical is fine. Will pursue checking the filter and water lines.
  • robert samples May 11, 2010
    do you have the model with the filter in the front or in the back on the side
    Scholar:
  • 72 Answers
Pull the filter and have someone barely turn on the water to see if it's even making it to the filter. Then check all lines for kinks. Then there are two water valves operated by solenoids near the compressor compartment. One is for the icemaker, and should only engage when it calls for water on it's own cycle. The other one is for the water. Have someone push the button and check for voltage at the connector. If you're getting this check to see if you hear a humming noise from valve when engaged. If not, the solenoid is shot and you need a new valve. Or if you hear it engage but are not getting water through the valve, unhook the exit and put a length of hose on it into a bucket to check this. Hope this helps.
Posted on Jan 27, 2008
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Model 253.54673304 water is not dispensing from door.ice is ok. both circuit boards were changed.new filter installed .ice is being made and dispensed.all 3 motor are working, but no water from dispenser.
You replaced motors? Did you replace the water solenoids on the back of the Fridge also?Sounds like you have either a wire or 2 disconnected from your cold water solenoid in back of the box, or your refrigerator compartment is freezing at the bottom and blocking your water flow to the cold water valve. Your cold water tank is located at or near the back and bottom of your refrigerator.
Mar 13, 2010 | Refrigerators
This fridge won't dispense water. It did this morning, nothing done all day that could affect fridge or water supply. I'm an engineer and I know a little about tracing problems. I checked the line in at...
my guess is things work till they don;t . and if your problem is simple we can solve it as. 2 mind's are better than one . if the frig is running longer to keep cold . it could be dust on the cond coil . or the cond fan running slower than it did yester day . . so clean condener and ck fan. and set the tempt in fresh food to a warmer seting . for 24 hr. . also the water valve may have failed as it 's a dual valve one side for ice and other water .. . on filter models 3 sol are on valve .. mm hope this helped. mm
Jan 06, 2010 | GE GSH22JFT Energy Star 22.0 Cu. Ft....
Liquids frozen in refrigerator, no water from water dispenser
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Kenmore 53642 / 53644 Side by Side...
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
121 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
