Question about Intel D845GVSR Motherboard
Liquid spilled on laptop computer keyboard
Spilled approximately 30ml of water onto leveno thinkpad Z60m keyboard. Power cord removed immediately then 30 seconds later battery removed. Unit then turned upside down. Attempted to power up 2 days later with no success. Presently the unit will not power up. When plugged into a power outlet, the power cord indicator and the battery indicator lights come on. The Leveno manufacture tech had me disconnect all power sources, push the power on button 30 times and on the 31st time hold the power on button down for 30 seconds. This didn't reset the system either. Unit still will not power up. Can you help or advise?
  • 1 more comment
  • Anonymous Sep 08, 2008
    powered down hte computer and dried the key boards
  • bocabroker Jan 15, 2009
    I spilled wine. At first the poer light lit up, but nothing else. No that doesnt even lite. Should I leave it unplugged a few days?
  • Motoi  Bogdan
    Motoi Bogdan May 11, 2010
    Hello, please reatempt to open a live chat so I can help you there. If you are unable to do this please reply here if you want more informations. I tried to take the problem through the live chat system but received an error.
  • 36 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
82
Posted on Mar 13, 2009
  • 55 Answers
Ok " bet there is still water in side , i would unplug unit take a small hand hair dryer set it on warm not hot and go over key board, may take awhile to dry.
only other alternative is to take it apart and dry it
try the hair dryer first.
Posted on Jan 27, 2008
I spilled salad on my computer. Curser works, but clicking gets nothing
Need to know if it's a laptop or desktop. Was the food spilled onto the keyboard or into the CPU? If the spill occurred to a desktop (detachable) keyboard, simply buy a new or used keyboard. Not expensive. A laptop is more costly to fix - requires removal of case. You can always use an external keyboard with a laptop -just plug into USB port.
You may be able to clean an external keyboard by repeatedly pressing the various keys where the spill occurred. If all else fails, get some electrical contact cleaner from Radio Shack or Auto Zone, unplug the keyboard, and spray cleaner sparingly around the keys where the spill occurred. I would not spray a laptop - too much electronics to fry. After spraying again press the keys repeatedly. Replug and look for improvement. By the way, USB keyboards are cheap on Ebay or Caigslist. I get them for $10 each,
Mar 06, 2014 | Apple MacBook Air
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
How do i know if a motherboard is burned out after a liquid spill
what liquid was spilled into the keyboard ? water will dry out in a few days, but if it's soda then the motherboard/cooling fan will have to be cleaned
Jun 10, 2012 | Dell Inspiron 15R Laptop
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
Will not power on, spilled a tablespoon of water on keyboard
liquid spilled on laptop is bad news, even thou it might be just a tablespoon, on the right spot might render your laptop useless, its recommended that you Do Not turn on the laptop, remove batt, allow it to dry for a week, if the laptop does not turn on then its possible that internal components might be affected/damaged. if the system is still in warranty and covers accidental water damage, call your manufacturer, if not, bring it to your local computer shop for repair...
Hope it helps!
Mar 05, 2010 | Computers & Internet
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
I spilled a small amount of coffee onto the keyboard while the computer was in use. I immediately turned it upside down and dried it off. I cannot get it to power " on"
Don't power it on. If that is doesn't seem kind of all water proof kind. Take out the battery and the AC power supply. Turn the laptop upside down without closing the screen monitor and let the coffee be out. Dry it/or take it on a reputable shop( I may suggest).
Have it clean. Hope it doesn't fry something inside.
Sep 21, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Intel D845GVSR Motherboard Logo
852 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
