Question about JVC AV-48WP30 48" Rear Projection Television
Convergence If I turn off the set will it reset itself. The problem started yesterday, today I tried to reset-no help. Turned off the set for a while turned it back on and most of the problem reset itself so I turned it off and unplugged it--will that help?
  • 4,402 Answers
Convergence amp ic bad
Posted on Feb 01, 2008
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
I have a WS65711 - 3 months ago I replaced the Convergence - Today the TV was on then turned itself off. I have tried to turn on but it just turns off after 30 seconds
Did you do the diagnostic self check:
when green power light goes off on the front of the set press and hold both Menu and Input(Device) buttons for 5 seconds and release both.
Power light will blink two digit error code like: 2 pause, 2 and repeat it at least 5 times.
Let me know what code you find and I will try to help you.
Jan 05, 2010 | Mitsubishi WS-65711 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Jul 29, 2009 | LG Dare VX9700 Cell Phone
Is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
May 15, 2009 | Weather King 10AJA4201AH Air Conditioner
Sony dp-51ws510 made 11-03
If your tv is Sony KP-51WS510, then it has problem in convergence ICs or Board and needs to be replaced.
Best Buy has no idea about Bulb, this TV is 3 CRTs rear projection system and has no Bulb or Lamp inside.
Need further help, let me know.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay...
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay open so can not reset television. Any one with ideas as to what has gone wrong?
Jul 11, 2008 | Televison & Video
Convergence-red off set
The issue with your set is convergence mis-alignment caused
by a defective IC....change both STK392-110...mounted on
large heatsinks....check nearby resistors for over-heating.....
Moderate tech skills necessary......................T.
Jan 27, 2008 | JVC AV-48WP74 48" Rear Projection...
Ghost images on tv
Bod convergence IC's. Try doing a reset of the TV first by pressing and holding the ACTION and POWER buttons while the set is on. A CHK screen with diagnosis will come up in about 5 seconds. Once that happens release the buttons and shut the set off and then turn it back on. If problem still is there then convergence circuit problems need to be fixed.
Mar 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
27 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
