Battery life seemed very short (recharg Energiz AA). Bought new batteries, put in camera, still flashed low battery symbol. Turned off and on aagai. Now flashing a red squarish symbol in upper L. Tried all buttons and whistles. Now nothing. Turns on, lens everts, flashes camera and pict (red and green) symbols 3-4 times, turns off. No light thru screen, no pict seen.
Brand new batteries. Lens everts and folds back. Red and green light flash a couple of times and that´s as far as it goes. Any ideas welcome!! Brand new batteries. Lens everts and folds back. Red and green light flash a couple of times and that´s as far as it goes. Any ideas welcome!!
Drains batteries way to quickly. My BF noticed how many batteries I go through and said something is really wrong. I have spent a small fortune in batteries and am getting more and more frustrated.Drains batteries way to quickly. My BF noticed how many batteries I go through and said something is really wrong. I have spent a small fortune in batteries and am getting more and more frustrated.
You can't post conmments that contain an email address.
Firstly clean the contacts where the battery resides, with some Isopropyl alcohol or any electrically spray. You will need to open up the camera to get to the circuit board. Take NOTE DO NOT touch the Capacitor, unless you discharge it. Locate where the battery leads attaches to the circuit board and give the contact and the circuit board a wipe with some Isopropyl alcohol Sometimes the board and the contacts might have some corrosion. A little cleaning helps.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
You can try updating the firmware if it is possible first.If this doesn't help then try removing the batteries off the camera
and allow the camera to reset for an hour and then put them back. If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you
switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH:
This is the best solution for enjoyment and cost savings. NiMH
batteries typically last longer per charge than the average alkaline
batteries. NiMH batteries are rechargeable batteries, so they can be
used several times and thereby reduce the expense of continually
purchasing new batteries. NiMH batteries are typically sold with a
power adapter for charging. The life of these batteries can often be
determined by the mAh rating, the higher the mAh rating on the battery,
the longer that they will last. NiMH batteries do not have the memory
effect associated with NiCd batteries, which means that these batteries
can be recharged at any time and at your convenience (you do not have
to wait for the batteries to completely drain between charges).
Lithium:
Energizer has introduced a new series of Lithium batteries that provide
optimum performance and long life for disposable AA size batteries.
Laboratory studies shows that Lithium batteries last more than three
times as long as standard Alkaline batteries. This means many more
hours of fun and satisfaction with your digital camera. These lithium
batteries are not rechargeable, they are long lasting.
Alkaline:
Using the LCD display, downloading images, playback, zoom and flash all
require some battery power to operate and may decrease the number of
shots per set of batteries. Performance may also vary based on the
Alkaline batteries selected. To significantly increase battery life, be
sure to turn off the LCD when it is not in use. The LCD consumes the
most amount of battery power. The benefit of being able to use alkaline
batteries is that you can find then almost anywhere if needed.
Manganese:
If you are using manganese batteries, the typical battery life will be
about 2 - 5 shots. Then the camera will indicate that battery power is
low and may shut-down. To avoid this experience, use either Alkaline or
NiMH batteries.
Optimum Solution: Use a set of NiMH batteries
for longer use and to reduce the expense of continually buying new
batteries. It may also be a good idea to keep a spare set of NiMH
batteries for other devices that require AA size batteries on a regular
basis. Use AA Alkaline batteries when the NiMH batteries need to be
recharged and you want to continue enjoying the use of your camera.
Goodluck, Please don't forget to rate the solution as fixya..
It seems there is some where inside the camera leakage..
Are you using Li-ion rechargeable batteries or AA batteries
For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
I have the same problem too. It's just started happening. The camera is about 3 years old. I've cleaned the battery contact points with an eraser and ensured there's contact. All seems fine. I only get about 5 shots out of brand new AA batteries, then a black screen with message 'change the batteries'. Can anyone help?
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
For what its worth I had this same problem with both rechargeables and
alkcalines. Fresh batteries were rejected after just a few shots and
were clearly NOT dead. Solution seems to be either use Sony's NP-NH25
cybershot battery which is made of two AA batteries jointed at the hip
or use generic rechargeable NiMh batteries with a capacity superior to
Sony's battery (>2500mAh).
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
