Question about Irons
Removing limescale from iron and steam chamber.
What is the best way to remove the limescale from the inside of the iron and the steam chamber. Is it OK to use limescale remover inside?
  • IroningGuru Apr 20, 2008
    I have the B&D D2020 and the Clean pop up. I moved the knob to Clean and holded there for a while and steam and water kept coming out but the Clean idiot light never when off. Did I miss something? HELP as this is the second (same model) iron I have gone through from B&D. Not a happy camper...
  • Anonymous Nov 28, 2008
    I LIVE IN A HARD WATER AREA AND MY STEAM IRON NO LONGER STEAMS. HOW DO I REMOVE LIMESCALE?
1/4 C. Apple Cider Vinegar : 1/4 C Water
Pour into the iron and let it steam through; have anything that you want to have a permanent crease -- like pleats in a skirt or the front seam of slacks? The vinegar/water mix will make it a strong pleat. When pleated skirts were the fashion in the 70's, I had a white gaberdine skirt and used clear vinegar to avoid any discoloration, and the pleat would not quit!
Posted on Oct 05, 2008
  • 2,039 Answers
1part descaler 1 part water shake it and rinse very good
Posted on Jan 27, 2008
Swan steam iron 2200w
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water. Descale completed.
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Nov 30, 2013 | Irons
How do I descale my iron
Oct 29, 2013 | Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
The iron heats well and I put the water in, but even when set above the steam icon, pushing the white steam button does nothing. No steam no spritz. When I opened the water chamber to let the water out, I...
Before you go through the process of taking it apart, buy some clr or a similar lime and rust removal product and fill the iron with that, let it sit a while and then dump it out and fill it with water a few times. Often if tap water is used, internal deposits will form and block off the passages, same as what happens in your car radiator over time.Most steam irons work better if you use distilled water in them as there are no dissolved minerals in that. Most replacement parts cost nearly as much as the iron itself and it's generally not cost effective to repair them.
Jun 23, 2011 | Black & Decker Gizmo C520 Iron
How to clean lime scale out of iron tank
All you need for this is a cotton cloth and white vinegar, a small amount. And you have to rub with cotton cloth for the limescale. Vinegar will act and the limescale will disappear from here.
If it doesn't help you can mix the vinegar with baking soda and it will be a good start point.
When you have finished to polish and to clean the outside, you can clean your iron from inside. For this you have to put a small amount of vinegar and you have to mix it with water.
You have to switch it on to wait. And press the steam. All the limescale will come out of there.
You see? And your iron is shiny and clean, from inside and from outside as well. .
May 19, 2011 | Tefal Irons
I have a Bush IN632 steam iron which is not generating steam. Can anyone point me in the correct direction as to what the fault may be?
took mine apart found that the base unit had limescale build up to such a level that the whole water chamber was full of limescale. Need a special security screwdriver
Jan 30, 2011 | Oreck TS100 Iron
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Philips Azure self-cleaning steam iron
philips do not have a manual for this iron online, sorry contact them if you want; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=IR_STEAMIRONS_SU&cat=HOP_IRONS_CA&grp=HOUSEHOLD_PRODUCTS_GR&session=20070313063306_83.37.63.254&ctn=HI296/54&slg=ENG&scy=GB The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Mar 05, 2007 | Philips HI-296 Iron
Irons Logo
4,680 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
