Question about Whirlpool WTW6600SW Top Load
Flashing F 50
The washer is flashing F50.
  • 2 more comments
  • fostersinc Feb 04, 2008
    I have f50 code. What can I do to reset without calling service?
  • mark_eanes Feb 04, 2008
    We ended up calling Whirlpool. It wasn't the motor, ("they rarely have a problem with the motor"). It was the computer board, (the computer in these washers are kinda temperamental"), and the RPS sensor, "just in case" It was no longer under warranty, just expired(!!!) ,but we complained and they are paying for everything. I have heard from a lot of dissatisfied customers, mostly b/c the damage it does to the clothes. Especially hoodies and the like. Hope this helps
  • robert samples May 11, 2010
    f50 is the code for a stalled motor see if the tub turns freely and we will go from there
    select stop cancel to clear the code see if it resets
Mark eanes, were you able to get your washer going again?
Foster
Posted on Feb 04, 2008
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: F50 error code and Whirlpool Cabrio
problem with the RPS(rotory positon sensor)sensor. id call manufacture for repair
Posted on Feb 23, 2008
SOURCE: Whirlpool Cabrio code F50
I have the same problem with my Whirlpool Cabrio. This morning it flashed F50 and now it won't spin. Called Whirlpool and they say the code refers to an electrical issue and that's all they said. Obviously there is an issue with this washer that many others have experienced. Whirlpool should look into this and consider it a recall issue.
Mike B.
Posted on Nov 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: My kenmore elite oasis washer model # 110.2703 shows code F-50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
I am getting a F50 error during the rinse cycle - what does this mean?
here is what the F50 error code means and what must be checked when it comes up
F50
(F50)
Motor Stalled F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
Jul 30, 2011 | Kenmore 23822 Top Load Washer
MOD# WTW6600SB2 HAS A F50 AND WANT SPIN OR WASH WANT DO ANYTHING EXCEPT PUT SOME WATER IN THEN QUITE WHAT IS THE F50 AND WHY IT WANT WORK
F50(F50)-Motor Stalled
Jan 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer, is flashing F then 50. It will start back for a second then stop and start flashing that again. What can I do? WTW6300SW
The F50 error code is a stalled motor error.There is a part called a "Rotor Position Sensor" that sees the motor running.This error will display if it does not see motor movement during a cycle.You want to make sure that the spin basket turn freely.Turn the basket by hand and it should turn freely.If it does not turn freely then it could cause the F50 error.If the basket turns freely then the problem is most likely the main control or the Rotor Position Sensor has failed.I recommend having a technician to
check this problem.
Apr 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Washer starts then beeps continuously and flashes F 50??? Can anyone tell me what this means?
senses no rotation.
Does basket turn freely? If not, determine cause of friction.
If basket turns freely, see TEST #3, Page 10.
Mar 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F 50 code after just having faulty circuit board replaced
May 02, 2009 | Washing Machines
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't fill, rinse or agitate; washer stops, first with F50 code, then F__ Code. This washer was installed 1/28/2007 and nothing has been changed in it's use or location. This is a Cabrio Automatic...
F50) Motor StalledF then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.•
i would call manufacture with the issue your having and demand they cover the problem as youve seen this same problem listed in multiple locations on the web(seems an ongiong issue with that model
Apr 06, 2008 | Washing Machines
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Feb 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6600SW Top Load Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal De
