Question about Acer AL1916W 19" LCD Monitor
Al 1916 problem
It was all fine but one day the problem started with my monitor is that when i press auto button, for a instant shows vary sharp and bright colours which were itz original settings but it rolls back to very dull and blurry image.
now im unable to get those settings on my screen ,the pictures are very dull and some of the screen is so brigth that i cant look at i for a long time...
plz assist me.
  • Anonymous Jan 27, 2008
    have a new hard drive yet this screen doen't want to work with the hard drive wow is there that much of a diference ,,,,,,,
Auto, <, > and menu and on/off buttons are not working for my Acer LCD Monitor AL1916 - any solution?
Posted on Sep 05, 2009
    Champion:
  • 207 Answers
Really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Posted on Jan 27, 2008
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Copier will not run.
Scott,
I had the same problem, if this is the AL 1551CS...called a local repair shop who kindly saved me a $75 service call by giving me the solution.
On the control panel, the button on the right is 'clear', with a 'C', and the one on the left is the 'auto' button, with no symbol.
Press 'Clear' once, press 'auto' once, press 'clear' again, the press 'auto' again (do all of these slowly because the copier enters different states or actually 'resets itself' as you complete each phase).
Next enter the number '24' in the number of copies and press start.
Then enter the number '7' in the number of copies and press start.
Now press the 'clear' button several times to back out of all of those steps and the copier will reset.
Should be ready to go. If not turn it off and on to reset.
This may work for other versions of the AL series, but don't know.
Paul
Feb 11, 2010 | Sharp AL-1551CS Copier
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Mar 25, 2009 | Sharp AL-1217 Copier
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
AL 1916 s
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 11, 2008 | Sharp AL-1000 Laser Printer
Sharp AL-1655CS
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display1.gif should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies1.gif.
Jan 07, 2008 | Sharp AL-1655CS Laser Printer
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
335 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
