Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
My Lacie 500GB drive shuts my laptop down when i connect it.
It was working fine one evening and when i connected it the next day it caused an error on my laptop resulting in it restarting. My laptop works as usual when the drive is not connected but the same thing happens whenever i connect it.
I managed to sort it. I plugged my drive into another computer and deleted recently downloaded files, after that it worked fine with my laptop. Reckon you should try it on a mates computer and see what you can do.
Posted on Feb 24, 2008
Similar issue: my notebook hangs instead of restarting. i thought its the usb2.0 of my rather old(3yr) notebook. but i bought a cheap usb box for my old 120G hdd and it plug-n-play like a charm on the same old notebook/same usb port. quite frustrated with this Lacie 500G beast.
so i ended up backing up my notebook using the 1-click backup of Lacie but using my old 120G hdd instead of the new Lacie500G. but then, search as i would through the Lacie documentation, i see no mention of how to restore the data... still looking...
Lacie serial number 1214802236941cr
Try connecting the LaCie to another computer. If this still does not work then the LaCie is faulty.
Nov 20, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
Jul 20, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
LaCie 500GB portable hard drive is giving error 43. It was working fine for a few weeks and now I can't get into it from either of my computers. I tried uninstalling the USB Controllers but still same...
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If a different LaCie product is available, borrow the power cabling from that unit to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to a second port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test.
Then run
Dec 22, 2010 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
My mac wont find my lacie external hard drive
do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Aug 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hi if I connect my lacie on the laptop it doesn't
That's why it's called 'Plug and Pray.'
Try plugging in the drive while your laptop is off, then power it up.
Watch the lower right quadrant of the Desktop to see if Windows pops up a box that says 'found new hardware.' If it does, Win may have a driver in its library and install it.
Jul 18, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this?
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB external HDD stoped working ?
It sounds like its an internal problem with the pcb board inside,which may not be an actual problem with the hdd it self but the mother advice would be to change the board that links between the hdd and the usb cable.
Jul 19, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
99 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
