Question about Panasonic CT-36SX31 36" TV
My Panasonic CT-36SX31 picture has an hour shape
The tv runs well, it has a clear crisp picture. The colors, tone and contrasts are great and the brightness is still perfect. But within the last few months the picture had bowed at the right and left sides so that it has an hour glass look. The bowing is semetrical and extends in a couple of inches in on both sides. I have tried some of the typical adjustments outlined in the service manual using the remote control and can not correct the problem. I have been told there might be something wrong with something to do with the "high voltage" or something with the "pin cushioning"? I am not sure what either of those things are or what relevance they would have. I am hoping to find a simple way of diagnosing the problem and perhaps purchasing a replacement part.
I know the tv is an older model, but I would like to continue to use it. I have access to panasonic parts and someone who knows his way around electronic equipment who will work on it if I can diagnose the problem. You may contact me via e-mail at ancient_breed @yahoo.com
  • teachrfixer Jul 09, 2008
    My old Panasonic 32" TV (couldn't find model, but was purchased in late '95, so is probably the smaller version of the one mentioned in the problem) is doing the same thing (hourglass shaped picture). But the picture snaps back to "normal" shape after about 10 minutes. I'd be interested to know if there is a solution because now I'm shopping around for a new TV.
  • Anonymous Sep 23, 2008
    i too have this problem. It just started... same exact model tv and same exact problem. Is this a costly repair? I would rather get a new TV (and a lighter one!) than spend $100+ in getting this one fixed.
Expert: Ja D
Date: 4/4/2008
Subject: panasonic ct-36 picture problem
Question
QUESTION: The picture went to a funnel or hourglass shape and a single line of text apppears as three (1 blue 1 yellow 1 red )
ANSWER: George. Have not viewed this problem for a very long time. How old is your set? CT-36??-? what the rest of the model number. Could be the main AC line filter. They were known to go bad and give this symptom, but I'm talking 15 maybe 20 years.
---------- FOLLOW-UP ----------
QUESTION: James, The model is ct-36sx31 ,tau series + was purchased new in 2001.I unplugged the set for awhile trying to "reboot"it but that did not change anything.Thanks for any + all help.
if(zs>0){w(''+x2+'#b">Get the answer below
');zSB(1,3);w('
')} Get the answer below
Sponsored Links Barrington Medical Tech.MRI,CT, PET: Service-Parts Solution Siemens, GE, Philips, & Toshibawww.bmimed.com
Troubleshoot RemotelySupport Windows, Mac & Linux w/out Leaving Your Desk. Try It Free Now!www.Bomgar.com
TV Repair Near YouEnter your zip code & find info on local TV repairs. Search now.www.TVRepairMan.com
Answer
Well, the SX31 and TAU series chassis had some problems with a capacitor that creates pincushion symptoms. It is C832, a 220uF / 16Volt Capacitor. That would be the first thing to do and to replace. If not this we can dig deeper if you like. Let me know.
Posted on Aug 14, 2008
Take a look around (say, within 12 feet of) the TV... anything that can generate an electrical field? Microwave... refridgerator... old school stereo speakers...
Pin cushioned is a term applied to a picture that's doing what you described. Adjustments to correct that are typically found in computer monitors.
I have an identical television to yours and that adjustment isn't available. You could try degausing, but I doubt that works.
Posted on Mar 18, 2008
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
My Panasonic CT-32SC14 takes about 5-30 minutes for the picture to be displayed, and the color is red hued/high contrast. Adjusting the color controls helps, but its not a great picture. The longer the set...
hi,
You have to check the picture tube base socket. After some years of use the contacts of the base socket will become bad (normally the screen pin and focus pin). Just replace the CRT socket it will solve your problem. You can find the CRT base socket on circut board at the end of picture tube neck. Pull the circuit board straight to back,do not shack. It will damge the picture tube pins.And replace the socket with the same type. You will get it from any of the electronic spare part shop near to you. Remember one thing remove the socket from the circuit and keep it with you as sample when you are going to purchase a new one, Because there are different types of CRT sockets are avilable. Purchase one which is similar.
ok
Jul 07, 2011 | Panasonic CT-32L8 32" TV
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
Fuzzy picture, color and volume comes and goes
the main chip in the TV that controls all these options (sound - sharpness etc...) you will need to bring this TV into a repair shop - the transformer that blew up caused a voltage surge that fried this chip
Dec 08, 2009 | Panasonic CT-27D32 27" TV
I need Panasonic CT36SL14 service manual
tv powers up but no picture or sound. DVD works great has great picture and sound.
Apr 02, 2009 | Panasonic CT-36SL14 36" TV
No clear color
i had the same problem a year ago / this is not somethin you can fix by yourself
you shood get your camera to a laboratory that repares sony's camera because there is some chip they need to replace - if i recall somethin likr color mannager\spliter i don't have the wright words in english for this
Mar 09, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Picture distortion
refplace the regulator ic or transistor. chick zener diode. chick vertical capacitors
Sep 09, 2007 | Panasonic CT-36SX31 36" TV
Open Questions:
Panasonic CT-36SX31 36" TV Logo
250 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
