Question about Tao Spectare digital picture Remote Control
Photo key chain
No photo viewer found program terminated. this is message I get when clicking photo viewer icon
my e-mail marty132@comcast.net . Whats the solution?
  • davesun2000 Feb 19, 2008
    I also get the same error message when I try to invoke photoviewer except
    it didn't say "terminated", it says "termined".
    "no Photo viewer found, program termined"
  • kescarpaci Mar 15, 2008
    no photo viewer found program termined
    now what?
Connect to pc. Press 'on' button on keyring. Change from 'charge' to 'update', then press > button. Photoviewer will then load. Good Luck!
Posted on Apr 06, 2008
I don't know what you said,would you told me again.by cleary and slowly.
Posted on Nov 10, 2008
I tried all of your solutions - but no luck. Then even with my little amount of computer knowledge I fixed the problem. I went into my device manager when the keyring was plugged in (control panel, peform & maint, system, hardware, device manager. Then I clicked on the device and deleted the device driver. Then I plugged it in again, and when I plugged it in, it reinstalled the new device driver. THen when I pressed USB update and opened the program - it worked. So it must have had the wrong device driver associated with it. I stuffed around with this for hours, so I'm glad I finally solved it (I even returned 2 keyrings to the supplier as I thought they were faulty). Hope this works for you
Posted on Aug 17, 2008
Connect to pc. Press 'on' button. Change from 'charge' to 'update', then press > button. Photoviewer will then load. Good Luck!
Why when i click on ts no photo viewer found the desktop icon it say
Please specify which digital picture frame you are using. You mention that .... "I click on the photo viewer icon on the desktop and i get a message "no photo viewer found" ..... This is desktop computer setting issue. In order to view a photo on a PC, you must set up a file association with between the PC software and the file format of your picture.
May 01, 2014 | Photography
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
Feb 16, 2008 | Digital Products Monaco Ezcolor Photo...
When I try to install the coby dp 151 it says: cant find photoviewer or program that owns it. the program will exit. ?? confused
The error you describe, is also mentioned in the Setup Guide for the DP151.
When you connect the Key Chain to the USB port of your computer, on the Key Chain will prompt the message to select: USB charge or USB update.
For proper function of the Chain Key:
0) Before connecting the Chain Key, have the Photo Viewer software installed:
You need adminstrator rights to perform installation of programs.
Install the photo viewer from the CD or download this program
from the Coby support site:
> enter cobyusa.com in the address bar of internet explorer
> enter DP151 in the Product Search bar
now all support for the Chain Key will show
> run the DP151_PhotoViewer zip file directly or save the zip file onto your computer, unzip and run the setup.exe file later
1) Connect the Chain Key and Select USB update on the Chain Key.
Again, to be able to update, you need adminstrator rights.
2) Run the Photo Viewer on the computer.
Aug 15, 2010 | Computers & Internet
Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Nov 22, 2009 | Fuji Electronics - Others
Cannot load photos from my vista program unto my photo key chain
I solved this problem through persistence - clicking on everything I could find, I found out that I needed to clic on "Users" and then my name and then i could find the photo files. It would have been helpful if this information had been included in the digital key chain disc instructions.
Jan 06, 2009 | Yahoo Mail
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
Dec 14, 2008 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Vu-Me photo ball error message Photo Viewer Data Synchronize failed
Wicked! Got it working.
I had the same issue as described by the other posts. I run Windows Vista. I suspect the others are experiencing the same error message and are also running Vista.
Short Version of the Solution: You must run the Photo Viewer program as an administrator.
To do this:
  1. Close the program if it is open
  2. Right click on the program icon
  3. Select "Run as Administrator" - Yes you have to do this even if you are already logged into the PC with administrator privledges.
  4. You will be prompted to Cancel or Allow - Select "Allow"
It will now work.
Note: You may be asked for the administrator password if you are not logged into the machine as an an adminstrator already.
Hope this helps someone out there!
Nov 09, 2008 | Cameras
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
My digital photo keychain album
My instruction booklet says:
IMPORTANT: The keychain MUST be plugged in and in "update" mode in order for you to open the Photo Viewer progarm. If it is not plugged in, or is in the wrong mode, you will get the following error" No photo viewer is found, program terminated!
2. Once the keychain is plugged in and in "update" mode double click the Photo Viewer icon on your desktop to launch the application. (I wasn't able to double click the Photo Viewer icon at all, so I don't know what else to do). And for the rest of you that are able to double click it, I will give you the instructions.
3. Use Photo Viewer's file manager to browse photos on your computer.
4. Once you select a photo, it will show up in the crop marquee. Put the box over the area that you want to see on your keychain and click the POST button (arrow to the right). This will move your photos to the collection panel.
5. Delete any unwanted photos by selecting the image in the collection panel and clicking the X button from the menu bar.
6. Once you have all photos in the collection panel that you want on your keychain, click the "synchronized" button. At the bottom of your screen, you will see that the status has changed from "idle " to "download" and the black bar will show %complete.
7. Once the download is 100% complete and you get the following message, "photo viewer data synchronized complete", click OK, exit the progam and disconnect the keychain.
IMPORTANT: Do not disconnect the Digital Photo Keychain until the download is complete and you exit the photo viewer software.
Jan 14, 2008 | Digital Products Monaco Ezcolor Photo...
Can run photoviewer program for photo keychain
Your computer will certainly have its own program for viewing photos. For example, if you are using Windows XP, you just right click on a photo file and choose "preview". It can be difficult to find the photos on your computer if you have been using one of the silly organizers that come with cameras. You can search for a photo if you know its filename or for *.jpg to find all the photos on your hard drive.
Sep 11, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Tao Spectare digital picture Remote Control Logo
473 people viewed this question
Top Tao Televison & Video Experts
Are you a Tao Televison and Video Expert? Answer questions, earn points and help others
