Question about Panasonic PT-47WX49 47" Rear Projection Television
PANASONIC PT-51DX80A hello, my buddy has this tv and i am electronic smart but looking at other posts it lloks like we have a bad resister on the board but i will let you decide that, problem : i went over there to look at tv (had great picture) i asked what the problem was and he says sometimes the red horizontal moves over 1" to the left. so i watched it for about 20 mins tuned it off and then on and it did it. so i go in the menu and try to adjust the convergence and all colors work except the red, the red will move un and down but not left and right. thats the only problem with the tv set, thanks for your help! Lewis Jensen [email protected]
    Novelist:
  • 192 Answers
Normally, the main cause of this problem is the solder connection under the convergence IC's.
You would see rings around the legs that have bad solder joints.
My shop would replace both of the IC's.
I don't have a schematic in front of me, but, I'm pretty sure the IC's are STK392-110. We use the STK392-150 in place of them since they are a heartier IC.
When replacing these IC's, remember to use semiconductor compound on the back side of the IC when placing the parts against the heat sink.
Any questions, respond to this post and I will reply.
Posted on Jan 27, 2008
6ya staff
SOURCE:
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
My panasonic tv model pt 61lcz7 has turning on problam it takes 10 to 30 minuts to turn on please advise. mohahmmed
Your lamp needs changed, after removing the lamp it might still, look good, but it is bad. After a while the bulb builds up a internal resistance, and it makes the TV hard to start, and then it gets to the point where it will not come on at all. You can go to www.partstore.com and get a new lamp, and that should take care of your problem.
Oct 16, 2010 | Panasonic PT-61DLX75 61" HDTV
My 52" PANASONIC PT-52LCX35 does not come on after a power surge went off due to lightning. I press the Power Button to turn TV on, but green light just blinks a few times then stop without any sign of...
Remove the Lamp and look for a white fog inside. It is bad if it looks that way.
If thats not it, Call a good TV Tech to troubleshoot the problem. Lightning can do about anything to electronics.
Jul 29, 2009 | Panasonic PT-52LCX66 Projection Television
Need a wiring diagram
This site has a lot of service manuals with wiring diagrams for a reasonable price. Downloadable PDF in most cases. I have purchased 2 for RP TVs.
https://secureiti.com/servicemanuals/default.aspx
Nov 22, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Panasonic PT-51DX80A
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Check your hori out put transistor and next too it is a 1200pf 2k volt cap that goes bad.
Mar 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Pt-51hx41e panasonic tv power problem
CHECK VALUE OF LOW OHM RESISTORS, THEY SHOULD ALL BE EXALCTLY THE SAME.
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
229 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
