Question about Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
I have Sharp AR-5320 Copier Connected to USB Port on D-Link Print Server (DP-300U). The Print Server Status Show USB Port OFFLINE , How do i make the printer ONLINE for the print server .
  • Anonymous Feb 12, 2008
    I have the same problem. Anyone can assist me?
    Problem Solver:
  • 8 Answers
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Posted on Feb 21, 2008
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
I don't have sharp ar-5320 software, but I have the machine and fail to print using the USB port. Can I download the software? How?
Driver for Sharp AR-5316/5320 can be downloaded from this Sharp Official support link
Click Download to get the required drivers. The drivers are available for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP
Hope it helps! Good Luck! Thanks for using Fixya!
Sep 23, 2011 | Sharp AR-5320 Black and White Copier
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
May 12, 2010 | D-Link DP 300U (DP-300U) Print Server
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
Sharp AR 5320 USB Printer port does not working
The usb cannot be switched off in either service of customer modes. have you tried using the parrallel port? Maybe it is a computer issue, wrong drivers perhaps, try a different usb port on your machine
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address:
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
Sharp AR-5320 Black and White Copier Logo
1,455 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
