Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
http://www.ertyu.org/steven_nikkel/ethernetcables.html
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
