Question about XFX GeForce FX 5200, Graphic Card
How to fix horisontal lines on display ( see the picture)?
They stronger when system is restarted and then fading but never disappearing. They always stay the same.
  • mymomrocks3 Oct 01, 2008
    There is a light blue line down the middle of the dispaly on my XPS One I just got about one month ago. How do I fix it???????????????
  • mymomrocks3 May 11, 2010
    There is a blue line down the middle of my display on my XPS One. We have only had this windows computer for about a month. How do I get rid of this blue line??????????????
I would like for you to tell me why my email message is on the right side of the screen with blue lines a white and yellow on the left. I do not have horizontal arror bar at the bottom to adjust the screen.
Posted on Feb 15, 2008
    Problem Solver:
  • 10 Answers
Horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Posted on Jan 28, 2008
6ya staff
SOURCE:
Hy i have samsung ue40d5003bw and half of display (up) is horisontal lines with picture and half of the diplay (down) is clear picture.
Samsung uses a power board with one capacitor. (Ignore the video and input boards.) Check high voltage across the capacitor - should be 390 to 400 volts DC. If not the capacitor needs to be changed. Samsung uses 100 uf rated at 450 volts. I replaced it with 370 uf rated at 400 volts. (Did not have a 450 volts lying around.)
Nov 25, 2017 | Samsung Televison & Video
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
How do I fix vertical lines on from my projector?
try changing the refresh rate or aspec ratio of the projector and tell me did it do any good
Apr 26, 2014 | Panasonic Pt-ax100 Multimedia Projecd
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Tv turns on ok,first displays black screen with 2 horisontal lines and some static at the top,than slowly from the top down i can see picture,after 5 min i can wacht tv but i have 2 lines -horisontal and...
Hi Marcin,
First of all, thank you for posting your question here at Fixya.
To diagnose accurately the exact caused of the symptoms, please let me know the Brand and model/chassis number of your unit. It is printed at the rear panel, manual and on the receipt. It will help to narrow down the symptoms and locate the availability of parts online.
Jdvillanueva
Jan 20, 2012 | Televison & Video
I have a Haier 7"
U get some picture on some channel but very weak signal and fade out and get Error codes on the tv screen?Yes,than buy a stronger Digital antena design to get better and stronger longer recieving signal ranges.
Dec 15, 2010 | Haier (PDTB7) 7 in. Portable Television
XP Pro Problm
can you explain the problem more? what do you mean vanished? does the screen fade out to white or black, or there is a blue screen with white text, or does it restart the whole system?
Mar 05, 2008 | Microsoft Windows XP Professional With...
Open Questions:
SBCglobal MAil TelePHoNe [+]{1+/855+/536+/5666-} NuMbER KANSAS call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Avg tecHnIcal SUpPoRt [1 855536$5666 ]' Joey This AVG ANTIVIRUS USA phone number{ +1855-536 5666} is ranked #2 out of 2 because 7,728 AVG ANTIVIRUS USA techs tried our t55ls and information and gave us feedback after they called. The reason techs call # I:855:,:536 5666 is to reach the AVG ANTIVIRUS USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, AVG ANTIVIRUS USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVG ANTIVIRUS USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I855 5365666 and ways to call or contact AVG ANTIVIRUS USA with help from techs like yourself. Please help us continue to grow and improve this information and these t55ls by sharing with people you know who might find it useful. Calling AVG ANTIVIRUS USA Calling AVG ANTIVIRUS USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back t55l. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVG ANTIVIRUS USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVG ANTIVIRUS USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVG ANTIVIRUS USA's phone numbers against each other. Contacting AVG ANTIVIRUS USA in General While I855536 5666 is AVG ANTIVIRUS USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I855 536 5666 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to l55k at as well. One thing to keep in mind as you try to reach AVG ANTIVIRUS USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVG ANTIVIRUS USA.
Nov 11, 2019 | AVG Computers & Internet
See all XFX GeForce FX 5200, Graphic Card Questions
XFX GeForce FX 5200, Graphic Card Logo
1,867 people viewed this question
Top XFX Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
