Question about Canon PC-430 Color Copier
Canon pc 430 feeder problem
My canon pc 430 copier the paper feeder has stopped working, the paper doesn't feed? I found a spring 1 inch but, I don't know where it goes or what it does.. Help please
  • ladyship Mar 19, 2008
    I have the same problem but with 2 detached springs. I do not see where they can be reattached.
  • lesl2 Mar 02, 2009
    I have the same problem. I did find one spring a put it back on the left side. I could not find the other spring. Besides, the tab on the black plastic piece broke off, so the spring would not be able to be attached. Can you suggest a place to purchase the black plastic piece and the spring?
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Posted on Nov 08, 2009
  • 55 Answers
Ok if you look where the paper is feeding into the printer you will see wheels on top, they move down when feeding paper.
that spring you found helps put pressure on the paper feed wheels, if you look at the wheels look for a little metal finger with a whole in it, spring attaches to that .
there will be another small whole in the frame below that attache the other end of the spring to that whole.
use needle nose pliers to do this
Posted on Jan 27, 2008
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Using attachment to print 4x6 photos
The usual cause of this problem is too much 8 1/2 by 11 inch paper in the normal feed slot. Take most or all of the regular paper out of the tray before setting the photo feeder onto the front of the paper slot. When installing the photo feeder, make sure the photo paper container is extended by turning the big dial to the 2 o'clock position, then rotate the dial to the 10 o'clock position after the feeder is in position. Don't overfill either the photo feeder or the regular paper tray. It's pretty fussy about position and fit of the paper in the photo feeder.
Feb 21, 2009 | Canon i860 InkJet Photo Printer
Problems with paper feeder-wont feed through-chews up paper
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PC950 Copier
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? I have the same problem.. Need help or place to purchase parts.
Sep 02, 2008 | Canon PC-950 Black and White Copier
Old lexmark paper feeder slips
Nooooooooooo . Don't buye new Printer
It simple problem IT paper tray Relay has to be cleaned . Pls clean the Relay with the dry cotton cloth and refit it . It will Work fine ..
Thank You
Feb 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer will not feed paper
Mine did that too.
I found that propping the paper feed cassette up at the end away from the printer worked.
May 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Canon PC-430 Color Copier Logo
437 people viewed this question
old marine
old marine
