Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Oven door will not seal at top.
The oven door will not seal all the way at the top. Which lets heat out and brown stain on top of door. Is there a way to ajust the hinges.
  • robert samples May 11, 2010
    look at the hinges closely and see if there two bars they are the hinge locks make sure they are in the fully unlocked position pulled up and locked in a 90 degree position on the door hooks check the oven door seal look at the top to see if there is an indentation where the seal is engaging the oven cavity the heat may be coming the vents in the oven door
Ours does the same thing. The problem with ours is the seal at the bottom of the door, keeping it from closing all the way. It's pretty much burnt into an out-of-place position, which causes the top of the door to gap since it's not closing tight.
Posted on May 25, 2008
The same thing with mine. I took apart the door today and found the hinges a little bent. I think it should be ok to bent them the opposite way a little with some mole grips......and then I must remember not to move the stove out for cleaning by the oven door handle again (oops).
Door comes off (unlock hinges and lift up). undo 4 screws on the bottom edge and then two on the inside of the door handle then it comes apart - beware as it's heavy. The hinges themselves come off with two screw each.
Posted on Feb 05, 2008
Hi - I have tried to clean the internal glass panel of our Smeg cooker using an oven cleaner.
The brown stains are on the inner surfaces of the "sealed" glass panel.
Jan 08, 2018 | Smeg Ovens
HOW DO YOU REMOVE YELLOW STAINS ON TOP PART OF OVEN DOOR THAT ARE THERE BECAUSE OF HIGH HEAT FROM CLEANING OVEN
Hey friend, thank you for your inquiry!
I understand that your Electrolux range has yellow stains on the top of the door. Typically you should just use warm water and mild soap to remove any stains on your range. If that does not help to correct the issue I would suggest a touch up paint that can by typically purchased through your manufacturer or replacement of the door. I hope this has been beneficial. -Matt
Oct 16, 2014 | Electrolux Frigidaire Oven Temperature...
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
I got brown marks on the top of the oven door when using the self cleaning mode. It is a white oven and now it looks bad due to the brown marks. Is there a way to get rid of these marks ?
The brown marks are caused by some food residue burning off during the clean cycle and is usually very hard to clean off. You might try using a Mr. Clean Magic eraser with some soft scrub. If that dose not do it you may have to replace stained parts.
Aug 28, 2011 | Ovens
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Ranges self cleaning instructions
Hi
An oven is a standard piece of equipment in the kitchen of a home or apartment. Often, the original instructions for operating and cleaning the oven have been lost or are not included with the lease of an apartment or purchase of a pre-owned home. To get the most use out of your oven and keep it functioning properly, it is important to know how to use it.
Adjust the racks to the desired position. Some Frigidaire models feature heating elements on the top of the oven while others are located on the bottom. Generally, moving your dish farther away from the heating source will result in a slower cooking time or reduced browning. Choose the desired oven temperature and set by turning the temperature knob or manual punching in the numbers followed by the "Enter" or "Start" button. Allow the oven to pre-heat before placing dishes into the oven to bake.
How to use..
Open the door while standing to the side of the oven. Standing directly in front can result in burns from the hot air. Wearing a dry oven mitt, place pans onto the desired oven rack. If baking more than one dish, stagger the pans on different racks, so that one is not directly on top of the other. This will help ensure even heating. Close the door and set the timer, using the numeric key pad or up-and-down arrows followed by the "Start" or "Enter" button. If you want to encourage additional browning on top of the dish, set the oven to "Broil" after the dish has cooked through. Monitor the dish carefully, as food can burn quickly. Remove the dish when completed using dry oven mitts, and turn off the oven.
How to Clean..
Do not attempt to clean the oven until it has cooled completely. The oven's exterior and the interior frame can be cleaned using a sponge dampened with hot water and dish detergent. The glass portion of the door may be cleaned with paper towels and glass cleaner. For ease of cleaning, wipe spills as soon as possible after they occur. Wait until the oven has cooled and then clean using the sponge method. If this does not work, a spray-on oven cleaner can be used, according to the manufacturer's directions for a manual cleaning oven, or for a self-cleaning oven, push the self-cleaning button and allow the oven to cycle through the automatic cleaning, usually about 1 hour. Never scrub the rubber seal around the over door, as this can lead to deterioration and prevent the oven from sealing properly.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | Kitchen Ranges
Self-cleaning leaves a brown stain on the white part on my oven
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
Jan 30, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Burn mark
Most likely the brown stain will NOT come off, if the stain comes off the paint will come with it. Replacing the control panel is the option for making it look good again. Sorry to bring bad news.
Mar 02, 2008 | Whirlpool RBS275PD Electric Single Oven
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
579 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
