Question about Logitech Z-2200 Computer Speakers
Loud crackling / popping
No matter what PC I plug these into, the speakers producea loud crackling sound which increases with any attempt to turn up the volume. I've now tried these speakers with 4 different PCs and they all produce the same results.
any advice would be greatly appreciated.
  • Anonymous Mar 30, 2014
    Weird crackling noises that never happened before. Tried fixing it again to the computer.
  • 3 Answers
Read this at http://forums.logitech.com/t5/2-1-2-0-Speaker-Systems/Z-2200-Touching-the-remote-volume-knob-results-in-a-very-loud/m-p/369699;jsessionid=4ED1A1BC248CB27152E9281D845FAF4A
Hi, the crackling is mostly a result from dust and debris building up on the contacts of the volume knob over the years.
You could try taking some compressed air to the space between the knob and the pod.
and
Sometimes with the power off. Rotating the knobs from end to end will also help.
m/E
Posted on Nov 27, 2009
The volume controll need lubrication. I'm not shure how to open the controller box, but that's where your problem are.
Posted on Sep 02, 2008
    Problem Solver:
  • 14 Answers
Well gd stuart i think you need some new speakers
Posted on Jan 27, 2008
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Oct 01, 2009 | Music
Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Aug 26, 2009 | Dell WL6000 Computer Speakers
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Logitech Z-2200 Computer Speakers Logo
687 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
