Question about JVC AL A158BK Turntable
Table turns only once in a while.
Lately when i try to play a record, the turntable will not move when i lift the arm, it will turn sometimes, i was told its a switch malfunction at the back of the arm.
any ideas?
The problem is probably the belt. When a belt gets old it tends to stretch and/or get stiff. Listen to see if you hear the motor turning. If it comes on when you lift the arm, it is not the switch.
Posted on Apr 15, 2008
6ya staff
SOURCE:
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
The tonearm on my crosley turntable doesnt automatically lift up at the end of the record, what do i do?
At the pivot point on the arm there is an indexing adjustment screw. With the unit running and a record on the table, put the are into the lift area on the record and turn the indexing screw until the arm lifts itself.
Dec 09, 2012 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Juke box will take coins but won't play record
WHAT IS THE POSITION OF THE GRIPPER ARM(CALLED GRIPPER ARM THAT GRABS RECORD?)
OVER THE TOP OF THE 50 RECORDS? NEAR THE TURN TABLE?
IS THE OPERATE SWITCH IN PLAY POSITION ? OFF POSITION ?
DOCTOR FIX.
May 09, 2009 | Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
JVC AL A158BK Turntable Logo
230 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
