Question about Brother MFC-8460N All-In-One Printer
Printer says there is no paper, therefore it won't print..........
Hi, the printer won't print, says there is no paper. There is paper, plenty of it. Help please. Thanks,
Shelly
  • 749 Answers
I have read some news about the problems of this brand and it's a lot "No Paper" is one of them... Try decreasing the amount of paper in the tray, remove half of it... then try printing...
Post me back when it doesn't work...
Posted on Jan 27, 2008
  • 689 Answers
Hi Shelly
This is unfortunately very common issue about MFC-8460N, There are few steps you can try, Set to factory default (Reset), move the roller manually so sensor will detect new position or locate the paper detector and bypass it. There are many users have been complaining regarding the issue that you have, Before try the troubleshooting that i have suggested please do call the hotline of Brotherif you have ongoing warranty. Some cases Brother accepts their fault on this known issues and provide solution (can be free of charge). As an experienced expert I suggest you to contact Brother (1-800-276-7746).
If you cannot find any resolution please post we will try our best to help you.
Good Luck
Samsung 4623 says I am out of paper but there is plenty
Dear
Pl. detach the paper try and see bellow the printer base a small plastic lever is there, push that lever upward, if printer goes ready, check the floor of the printer and tray else some mechanical adjustment is required or put a bunch of paper.
Thanks.
Feb 27, 2015 | Samsung Office Equipment & Supplies
Printer roller will not engage paper
Make sure you have plenty of paper in the tray, this may help the printer pick it up. if you don't have lots of paper add an A4 sized magazine, book or old printed paper in there, to full the tray.
Is there a way to manually insert the paper from the back, some printers have this feature.
Feb 10, 2014 | Office Equipment & Supplies
I have paper stack in my Brother HL2140 laser printer, how I take the paper?
Hi cillacp,
Ok, firstly some may say turn off the printer before removing the paper, but I find it easier with the printer on. (hopefully you know abit about electrical dangers :) This is because when you start pulling the paper the printer will automatically rotate to help get the paper out.
Ok the mistake many people make when dealing with a paper jam, is they try and pull the paper out from the wrong end. You should therefore open the cap of the printer, (same cap where you change the toner, or sometimes you can open the back of the printer). then pull, preferabble using two tweezers, one on each end of the paper towards where the paper would go if it were printing normally. i.e. pull towards the exit of the paper if printing.
Hope this helps abit.
kc
Feb 19, 2011 | Brother HL 2140 Laser Printer
My cartridge seems to only move when I move it manually - therefore, it doesn't print- I welcome any suggestions.
Hi thanks for asking please check the printer to see if anything stock inside for example make sure there is no paper stick up inside printer. If there is paper stick up in it you should carefully remove it restart your printer and then try to print,so you can see the response of the printer.
Thank you
Jun 10, 2010 | Office Equipment & Supplies
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
Laser printer does not print
Hi there it may just be that the paper tray springs are not pushing the paper higher enough not making contact with the paper detect sensor arm. Or the sensor arm is broken and will need replacing. Check the tray springs also check the sensor arm you will see it if you remove the cassette and look inside there will be a black plastic lever hanging down when you put paper in this lever should go up as the paper acts as a barrier thus telling the machine that there is paper in it.
Thanks J
Jan 28, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC-8460N All-In-One Printer Logo
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
