Question about SanDisk Sansa e260 MP3 Player
Problems with my sandisk sansa mp3
It seem that everything is fine but the speakers are not working anymore,you can see that the music is goin on but I can`t hear anything and it waas working perfectly fine my boyfriend just give me this las week,what can I do to solve this problem?
  • Cory
    Cory May 11, 2010
    Are you able to hear music with headphones? What connection are the speakers on; USB? 3.5mm Jack? Or does it fit into a custom base cradle?
    Do the speakers have a power connection?
Do any of the songs play? It may be that the song(s) are corrupted. If this is the case, delete the songs and try to download them from somewhere else or, if you uploaded from a cd put them on again and see if they work. It also might be the jack that these speakers are plugged into. Sometimes the port for the speaker plug is made incorrectly, and the plug is too loose inside to actually connect, but tight enough to stay in. If it's a base cradle, does it work? Are you missing any batteries( if battery powered), or is the plug in the outlet right? Is the player connected properly? Is it actually FOR the player, or is it only for a certain type of player that you don't have? It by 'speaker' you mean headphones, the wires might be disconnected in some places. If that's the case, buy some $0.98 headphones from walmart and attempt it with those. Are the volume bars on the player and the speakers high enough up?
Posted on Feb 01, 2008
Sandisc sansa (8GB) won't play music
i had this exact problem. i formatted my sansa clip and then re-synced it.
May 25, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 player tells me to synch even after I have done everything
Synch the Sansa to Rhapsody or whatever music service you got the songs from, instead of through Windows Media Player. As long as your music service subscriptino is still good, you should be fine.
Jan 02, 2009 | SanDisk Sansa e250 MP3 Player
My computer wont reconize my mp3 player
Down load the firmware on Sansa's website. I have a Sansa 250R and it wouldn't work with the new replacement usb (Griffin) cord I bought at Best Buy. So I bought a Sansa Fuze and the cord that came with it worked on the E250R. Huh? Yeah, go figure...and oh, that replacement Griffin usb cord I bought worked fine with the new Fuze. I came real close to buying a new battery for the E250R but instead invested that money in the Fuze.
Oct 12, 2008 | SanDisk Sansa e250 MP3 Player
Audio is messed up!
First, make sure you didn't download an instrumental.
Second, make sure the files are in a format that the player recognizes.
If both conditions hold, then upgrade the firmware - you have a corrupt DB.
Sep 08, 2008 | SanDisk Sansa e250 MP3 Player
I have tried EVERYTHING and NOTHING is working for this problem
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 31, 2008 | SanDisk Sansa e250 MP3 Player
Problem with max. volume
Not Mac compatible largely.
ALL Mp3 players have a disclaimer telling you not to play it at max volume. Get adjustable headphones to resolve problem
Mar 26, 2008 | SanDisk Sansa m250 MP3 Player
Sansa e280 "frozen" won't turn off or respond to buttons pushed
I had the same freeze problem and after doing everything I could think of I read the downloaded user manual and found the answer was to hold down the menu button for 15 seconds. It acts as a power off button and cancels out the last operation thereby unfreezing the offending action.
Feb 17, 2008 | SanDisk Sansa E280 MP3 Player
Sansa Connect Problem
I had the same problem with my Sansa Connect. It refused to start up when connecting to my computer. I think it may have something to do with not refreshing my music every so often. I tried the Recovery Tool, but it did absolutely nothing. Same problem was still there. So, I did a factory reset and it worked. No problems. I would recommend refreshing music regularly to avoid this problem.
Dec 26, 2007 | SanDisk Sansa Connect MP3 Player
Sansa e260 problems : Music files freezes the sansa and restarts it.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250
or
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
