Question about Belkin (F5D7231-4) Wireless Router
Help i have just got a new computer, and i wont to ad it to my Sucre wireless connection. How do i get my network key?? i can remember the password that i put in when i set it up but that's all. can any one help!! cheers Tony
  • tonydtl Jan 27, 2008
    Hi thank's for that all sorted.
    Tony.
  • 40 Answers
I Would Reset It Theres A Area On The Back Of The Router As In Any Other Device! I Says Rest Push It In Count To 20 And Let Go ! And ReDo Ur Pass! And Install Software If You Want It Key'ed other wise u really dont have it install the disk! your pretty safe most people wont tap into it! i hope this helps! please mark how helpfull i am its much apreciated!
Posted on Jan 27, 2008
  • Marie Ragusa
    Marie Ragusa Jan 28, 2008
    your welcome im glad i could help!
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Tip
Wireless Network Key (WEP/WPA) Recovery
It frequently happens that one loses or forgets his/her wireless network key. Normally this key is cached on your computer and it connects automaticly, but what to do when you have a new computer and you can't remember the key you originally used( and you don't have access to the wireless router) ?
Instead of resetting (the password on) the router you could try and recover the key from another computer on the network which does succesfully connect to the network.
One of the tools which can do this for you is NirSoft WirelessKeyView (http://www.nirsoft.net/utils/wireless_key.html). It's free, safe and easy in use ... just download the right version (32 bits or 64-bits) onto the computer which does succesfully connect to the network and run it.
on Aug 17, 2009 | Linksys Wireless-G WRT54G Router
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
My acess poin is not supported by the nintendo ds
Hi rodneyde,
f you're receiving that error message we need to access the Wireless Settings Page of your Router to change some settings. Keep in mind that if we change the settings of your wireless connection other machine that is connected to the network will be disconnected due to the new settings, so take note of the settings that we will be changing.
To access your router you need to use a computer that is connected to it. Open a Browser then type192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Settings Page try changing the encryprion to WEP 64bit and generate aNetwork Key. Remember the network key so that if you have laptops that are connected and will lose the connection that is the password that you need to input. If WEP 64bit wont work try WEP 128bit orWPA you can also disable the Security however you network can be access by others.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection. If you have questions put a comment here.
Rate me if this helps so I can hep others. Thanks for using Fixya.
Feb 05, 2011 | NetGear WGR614 Wireless Router
I forgot my password to acess my router. I am adding a second laptop to be used with my pc.
Here is how to reset a new password since you cannot remember your old one.
On a computer connected to the linksys now.
Click the link below
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is your password.. If it looks like **************
You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now found out, or reset your wireless password.
***Note*** If you changed the password.. The current computer will also have to reconnect to the network, and enter the new password.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Aug 30, 2010 | Linksys Wireless-G WRT54G Router
Can't remember password for wireless and so can't connect my new laptop
For you to retrieve the password of your Wireless Network, connect your computer to the router using ethernet cable. Access the router's page through it's LAN IP and go to the Wireless Configuration page to check the Wep key. Hope this helps.
Jun 13, 2009 | Arris SURFboard SB5120 Modem
Adding lap top to wireless network - need network key?
If you don't remember what the key is, log on to the router and create another one. You will have to change the key on all other wireless devices on the network.
May 18, 2009 | Buffalo Technology AirStation G54...
Wrt310n adding wireless laptop
If you are using windows xp :
Go to Start>control panel> Network and internet> network connections > right click on wireless network > select 'view available wireless networks' and select your home network and click connect. If it asks for a password i guess u have it or if u dont have then go to Internet Explorerand and type 192.168.1.1 in the address bar, it will ask for a username and a password, type admin as username and the same for password. it will take you to the lynksys page....then select wireless and click wireless security, it will show you the wireless password.......
If u have windows vista :
Click Start > go to 'connect to' > select the wireless network you want to connect to and the rest is the same as windows xp....
Hope this works out
Regards,
Anup
Apr 07, 2009 | Linksys WRT160N Wireless Router
Network key retreival
Is it possible that you never changed the default wireless key? If you didn't, the number in '[ ]' brackets printed on the bottom label is the wireless key.
If you've changed that from the default when setting up your wireless network, you'll most likely have to reset your router.
Of course, if you do a reset on your router, you will also have to re-enter your DSL account / password in the router
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't remember the Network key for our home wireless setup
Try logging into the router by opening you web browser and in the address bar type 192.168.0.1 , if you are prompted for a username and password enter them and click ok (username usually "admin" password usually "root" if they havn't been changed.
Go to the wireless tab and see if it is displayed in there, if it isnt then make a new one and save it but by doing this all other devices connected to it will need the new key putting in but at least you can now connect your new laptop and surf away.
hope this helps :o)
Jan 02, 2009 | Dell Latitude D610 Laptop Computer -...
Belkin (F5D7231-4) Wireless Router Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
