Question about Zebra Printer 140-751-00000
Printer Defaults Hi, I have this problem in my company with Zebra 140Xiiplus printers.Whenever the Printer is switched off and on Some settings like Head Close,Thermal transfer,print width are changing to their defaults both in printers and in pc. In all the printers we have an option called printing defaults which helps us to save the settings to our wish.How can we do it in Zebra printers.Please help me so that atleast settings like page size and headclose do not gets changed in PC?
Try setting up your sizes etc on the required printer in" printers and faxes" first and then access your print system , when you then select the "print" function you will find the sizes etc that you have set up in printers and faxes are already set for you , unfortunately it will only save for a few prints and then will default ,however it defaults to the settings you have already set up in printers and faxes
Posted on Jul 11, 2008
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
How can you configure Zebra printer 105sl (over network) to print labels in IE and have a regular printer from reducing the document size from a thin client?
I have this issue whenever I set my default printer to a label printer. Use the other printer as the default and set to the zebra only when you need it.
Dec 07, 2011 | Zebra 105SL Thermal Label Printer
Have a Zebra Z6M label printer. We configure it to settings we need to work. Then all of a sudden we are back to factory defaults at random times. Any idea why this is happening?
Your printer driver will overide the printer settings. Set the printer settings and save them. Then print config by hold the cancel while power on. Verify the settings are saved and correct. Then send a label to the printer and see if the parameters have changed. If they changed then change the printer driver settings to your preferences and try again.
Aug 09, 2010 | Zebra Z4M Printer
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Dimly label
Hi Cvetan, could you reset the printer to it's default settings. To do this you need to access the Menu, once you have accessed the menu you need to exit it. You will be presented with Save Permanent, cycle around until you find Load Defaults and press exit, it should say loading defaults. restart the printer and see how it goes. If the print quality is too light, change the settings in the driver under Head settings. Once you send the print you printer will pickup the new settings.
I hope this helps
Jul 03, 2009 | Zebra Z4M Printer
Printing issue with Zebra Z4000
Good Day
I trust that you are well, which interface are you using (Serial, Parallel or USB) on printer to connect to the computer you printing from?
Have you tried printing a test page from the print driver?
May 18, 2017 | Zebra Z4000 BARCODE LABEL PRINTER, 203DPI...
Zebra Z4M plus printing an extra label
Restore factory defaults. If this doesn't sort it out, get back to me and I should be able to point you towards the right solution.
Mar 31, 2009 | Zebra Z4M Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Zebra Printer 140-751-00000 Logo
241 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
