Question about Bronica SQ-A Medium Format Camera
Film back jammed
Can you tell me how I can get the film back off when it's jammed
  • EDRW Jan 27, 2008
    Hi There,
    Jammed meaning I can't take the film back off please help
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Jammed meaning you cannot advance the camera to the cocked position?
  • 667 Answers
Ok, The dark slide has to be in the right way. A small tab sticks out of one end that matches a small slot below the main slot where you put the dark slide. The tab will sometimes miss the release arm in that smaller slot
Posted on Jan 27, 2008
Paper get jam near fuser film
check pressure spring
lubricate fuser under film
ensure well assembling
Nov 12, 2015 | HP LaserJet 1010 Printer
Xerox 2520 copier when machine start some part lose there that, s why sound is coming out & only half paper is come out from output side.what can i do?
first check the paper size of casset detecting properly, if ok, check your fixing unit film...maybe the sound comes from the fixing film
Feb 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
My shutter got stuck at 14 frames.i wound it back but want to go back to the 14th frame,will this ruin the pictures i have already taken?
Could be that when the load builds up there is friction to jam the film. You must not take chance with the shot film and so try to click with the cap on the rewound portion and if the film is not advancing then it is possible that the camera must be checked with a dummy film to confirm on why the jamming takes place.It can be also due to failure of the loading mechanism
Mar 17, 2012 | Canon EOS-AE-1 35mm SLR Camera
I have a pentax 67 camera and the film advance lever is jammed. it will not advance without putting undo pressure on it which i am not willing to do. i have read many forums that have said this is not an...
Try pressing the film release button on the underside of the camera. This should unstick the advance roller.
If possible, replace the watch battery for your camera (inserted in the bottom, right by the teeny black button I mentioned above).
Change your exposure setting to Bulb exposure and back.
If all else fails, take your camera into the darkroom (or at least a completely light-insulated closet, bathroom, etc.), and pop open the back and recover your film. Hopefully you won't have too much wasted film on your hands.
Good on you, however, for not forcing the lever. Nothing good will come of that.
May 06, 2011 | Cameras
New film in Brother 885-now paper and fil jam
2 reasons.
1.You have not installed the film in correct manner
2.Your film is not geuine brother film.
Jul 30, 2010 | Brother IntelliFAX 885MC Plain Paper...
System error E007 IR2016 photo copier
i think the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck sir let us know how you make out.
May 18, 2010 | Computers & Internet
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
No error message displayed when film jams
Take it into nikon specialty shop for a service.
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Carriage jam
Mar 27, 2008 | HP Officejet Pro L7680 All-In-One InkJet...
Paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Bronica SQ-A Medium Format Camera Logo
148 people viewed this question
Top Bronica Photography Experts
pontelemon
pontelemon
Tony
Are you a Bronica Photography Expert? Answer questions, earn points and help others
