Question about Jetway MiniQ 765Twin (miniq765twin) Barebone
Western digital wd800
When i turn on com and press enter to load windows will not load and when i try to boot from cd to put fresh copy of windows on it just says inspecting computer config and then nothing els happens
  • 1 more comment
  • lyndass
    lyndass Jan 28, 2008
    hey there i did it at last i just went on the site and downloaded The Data Lifeguard Diagnostic Tools and set the drive to all zero,s that did the trick
  • Anonymous Mar 17, 2008
    my motherboard is defective
  • hecto07 Dec 07, 2008
    i have a wd 800 laptop disk
    and I would like to install in a new computer
    but at bios, the disk ask a password.
    Please help
  • 46 Answers
Sounds likie you m.b.r. Master Boot Record is corrupt. try clearing your cmos. use your jumpers on mb or remove coin battery and reinstall.
Posted on Jan 28, 2008
How to format a hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Dec 16, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
How to install windows 7 on a Western Digital Caviar Blue 640 Hard drive
if your computers motherboard is older than 5-6 yrs you might not be able to load windows 7
and you will need a minimum of 2GB of RAM
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps you
Sep 18, 2011 | Western Digital Caviar 500GB Internal SATA...
When i turn my computer on it loads but then a erro message comes up so i want to do a pc reset and i have looked online useing my laptop and it tells me when i see a blue dell splash bar come up to press...
The procedure is actually correct. but if your computer is fast you may miss it. try this, upon turning the computer on, start pressing the CTRL+F11 immediately. if you have reformated your HDD then most likely you've lost the recovery partition for the PC Restoration.
godspeed
Jun 23, 2011 | Dell Inspiron 531s Desktop Computer
NTLDR is missing press any key to restart message appears but cannot get it to restart
DELL Boot error.
  1. You have to go to the BIOS make sure the first, second and third boot device is set to cdrom. Put your startup disk in the CD drive.
    2. once you see a prompt that says press any key to contintue to boot to cd press the Enter Key Once
    3. When you have a prompt that says welcome to windows press R to Repair press F3 to quit and press Enter to create a fresh new copy of windows. we press R
    4. You will be given a dos prompt
    5. Type c:\> cd c:\windows\repair, <Press Enter>
    6. Type c:\windows\repair> del c:\windows\system32\SAM, <Press Enter>
    7. Type c:\windows\repair> copy sam c:\windows\system32\SAM, <Press Enter>
    8. Type Exit
    9. Restart the computer
Jan 03, 2011 | Dell Inspiron 1720 (dncwma1_1) Intel Core...
I want to install fresh copy of window xp but when i press any for boot from cd then after loading few files In window installion first setup system become halted and does not proceed. i cannot install...
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart if you have done this you might have a faulty lead
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 08, 2010 | IBM (02R4084) Motherboard
Ntldr is missing in pc and when i tried to boot xp cd it checks for hardware configuration and black screen appears
you just need to replace it, just use the boot disk for your os to boot the system up then copy paste ntldr into the root of c, if you have probs repost
Jun 02, 2009 | Western Digital 320GB MyBook External USB...
NTLDR is missing
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows, using bootable windows CD.
Mar 23, 2009 | E-Machines T2892 PC Desktop
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Try to format my hard drive it will not format. or at least i cannot find anything that has.. all it will do is copy over the old windows but i know there is a better way to clear everything off!
go into the control panel. click administrative tools. open computer management. click the tab called disk management. make sure the drive you want to format isnt the system drive. (it wont let you format while running) and format the drive from there. you can also choose the drive letter you want to format to. very useful if you are a neat person. (C: MAIN, D: documents, M: music, Z: dvd writer, V: virtual memory.........)
Aug 13, 2008 | Computers & Internet
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Jetway MiniQ 765Twin (miniq765twin) Barebone Logo
421 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
