Question about Belkin (F5D7233) Wireless Router
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
Can not connect to Internet my iMac via PAradyne 6211. The modem is connected via Ethernet. Do I need a driver for the modem? Please help.
  • VAL848 Jan 27, 2008
    Thanks for the help. I still have a problem with connection to Internet. Ethernet is connected, however, I can not connect to Internet. Should the Paradyne be in the router or bringe mode? What settings should be in place? When I try to establish connection - I have the message - No PPoP service was found - remove service name option. I do not understand what needs to be done.
  • 689 Answers
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
If physical connection is successful you can go to internet browser type and check your modem's settings. Please post if you need further assistance
Good Luck
Posted on Jan 27, 2008
  • ExpressFiX
    ExpressFiX Jan 28, 2008
    should be in router mode
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Internet connection problem Zhone 6211
After a while the net stops working then when i open the router page for the settings it starts back working
Aug 08, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Modem connects to Internet, but PC can't
Are you using a firewall? Did you tell the firewall that the browser has permission to access the internet (go beyond the local network of the modem)?
Jul 29, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Bridged Mode
Verify this with your ISP, but if you go into your modem settings, click on "Advanced Setup", click on WAN, when page opens, click "Edit". After clicking "Next", you come to the page labelled, "Connection Type". It is there you select what mode you'd like it to work in. When you are through selecting click NEXT till you get to the page with the SAVE button. Click Save and wait for page with FINISH to come up. Click FINISH and wait for the router to reboot(2 mins). Please write down the previous settings so you'll be able to undo whatever you do.
Mar 04, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
Paradyne Dsl Modem
Hi, If I understand you right, what you want is to use your Paradyne 6211 modem to share the Internet connection to 2 PCs. One is connected through the USB and the second through Ethernet port. Tried it on a Siemens 4200 and a Prolink Hurricane 9000, both worked and can be done. To be sure, the IP settings of the PC connected via Ethernet was set to manual configuration. In your case try IP, Subnet Mask, Default Gateway, DNS Servers - whatever your ISP are using. You of course can try and see if it works in your modem. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 03, 2007 | Paradyne (6211-A2-200) Router
Paradyne Vista Compatibility
as far as i think your system has not install modem as your isp line support so frist install the modem which your isp line needed go control penal >phon and modem >add modem from the list and apply ok
Sep 01, 2007 | Computers & Internet
You would have to refer to the manual to set up the usb connection, so as the router knows that the main pc is connecting via the usb and not the rj45 port. The only other thing may be that your router will recognise when you are connecting with the usb port, as long as it's the pc with the modem drivers on.
Oct 27, 2006 | Paradyne (6211-A2-200) Router
Belkin (F5D7233) Wireless Router Logo
134 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
