Question about Vacuums
Polti vaporetto lux xteam cleaner
Can't get the cap of the generator tank. Says there must be no pressure before it will open - well, the machine is cold now and it still jsut goes round and round, and won't undo
  • steamcleaner Feb 04, 2008
    fixed now - but thanks. it needed 12 hours to cool absolutely down, before the cap would release
  • 103 Answers
Ok, this may sound silly, but do you need to push down on the cap to get it off? Just a thought.
Posted on Feb 04, 2008
I cant unscrew the filler cap for my polti 950
I had the same problem with the 2400 model, because the filller cap is a safety cap it thought there was pressure in the tank so wouldnt unscrew just kept going round and round. It had a little water it it. I switched it on heated it up then switched it off and let it cool a bit. There was a small metal bolt on the underside of the tank which I could unscrew with a alan key. This let the pressure out, I then rinsed it out with cold water and hey presto the safety value released itself. hope this helps
Jan 04, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Vaporetto 2400 no access to water tank
The threads have probably stuck together with limescale. Push down with reasonable force while turning the cap, like you would if you were trying to get in one of the childproof bottles. This should crack the limecale and allow you to take it off. Then descale the threads on the top and machine using kalstop or whatever you use.
Jan 16, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
176 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
