Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Pairing Mode I have a Plantronics Voyager 510 but cannot get it to go into pairing mose - even when I press the correct buttons. What is wrong?
  • 11 more comments
  • Anonymous Feb 08, 2008
    i cannot get my plantronics 510 voyager headset to enter "paring mode"
    what do i do? it is soooo annoying
  • AlPowell Feb 24, 2008
    I am not sure how to set up pairing for the Plantronics 510. Can you provide me with instructions?
    Thanks,
    Al
  • Anonymous Mar 09, 2008
    i can not get it yo pair with my phone
  • durag Mar 20, 2008
    i have been trying to pare my bluetooth 510 and it will not go to red and blue paring mode what do i do.
  • londonstan Mar 24, 2008
    same here this plantronics 510 voyager pln headset must be faulty. it started to pair nicely but has given up on me
  • Anonymous Jul 06, 2008
    I can hear and speak through my bluetooth, but I can't answer and end a call using the control button.
  • Anonymous Aug 25, 2008
    My head set will not go into pairing mode, whether I have the device is on or off.  The device will turn on and off normally.  I am charging the device to see if that helps.  Has anyone run into this problem?  I need some help with it and I already looked the instructions up online.
  • Anonymous Sep 13, 2008
    how do I pair my plantronics 510 to a phone
  • RodneyF Sep 30, 2008
    Same problem. Used to go into pairing mode, does not now.
  • kanaly Oct 02, 2008
    I can't pair my PLT 510 with my Blackberry Curve.
  • Anonymous Feb 01, 2009
    I cannot pair my devise either, I already try all of the above, however in my cellular appears a message "No devise found"
    any suggestions?
    thanks
  • felicitas918 Feb 26, 2009
    pairing with Samsung A437
  • kevin_mason May 11, 2010
    510 voyager head st light dose not come on
I had the same problem..tried to pair it for hours but could not get it to do it till the battery ran out and i had to recharge it..
I later found out that it was not pairing because the batteries were low. If the battery gets below a certain level it will not pair the headset because it's trying to save energy. anyways after a full charge it paired just fine...hope this help you guys....
Posted on Nov 23, 2008
Had the same problem. tried it numerous times, unsuccessfully. Then turned headset around in my hands so I was using different fingers to press buttons, and it worked fine. So try changing how you are pressing buttons.
Posted on Jul 04, 2009
Posted on Aug 25, 2008
    New Friend:
I know this is an old posting but i had the same issue and thought I would post my fix. I have owned may PLT510 in the past and bought another last summer. As it turns out, I must have bought a Voyager Pro instead. Looks EXACTLY the same as the PLT 510. To pair it i had to turn it off, then Hold down the power button for about 10 seconds and it went into pairing mode. If your device asks for a code it is 0000. Mine did not ask. Hope this helps someone.
Posted on Jan 03, 2013
    New Friend:
Just thought that I should add what worked for me. My headset refused to pair with my laptop and phone suddenly one day and the only way I got it to enter pairing mode(red and blue led flashing) was to press the call and button while it was on and charging even though it was fully charged.
Posted on Aug 31, 2010
Thank you
Posted on Apr 19, 2009
I have the plantronics voyager 520, I have used them quite often, but can't get my new one to pair
Posted on Feb 27, 2009
I wonder if you all are having the same issue I did. I came here for the same reason, I was unable to make my 510 go into pair mode. Here is what "I" was doing wrong. I would press the call button and THEN press the volume up button, thinking that as long as they were held down at the same time for 3 seconds, and it didn't matter if both where pushed at the same time or not. It matters. Both buttons need to be engaged at the same exact time, not one right after the other like I was doing. Good luck!
Posted on Oct 09, 2008
Thank you. Instructions on the web clearly state that it needs to be off....
Posted on Aug 24, 2008
THE B;UE TOOTH IS SUPPOSED TO BE ON. THEN PRESS THE VOLUME UP BUTTON AT THE SAME TIME THE CALL BUTTON UNTIL THE LIGHT FLASHES RED AND BLUE, THEN YOUR READY TO PAIR
Posted on Jul 05, 2008
When you're pairing the headset the headset needs to be on first before you can pair it. these instructions are pretty helpful and show you step by step how to pair with pictures:
http://www.plantronics.com/media/media_resources/easytopair/index.html?WT.mc_t=EasyToPair&WT.mc_n=EasyToPair&WT.srch=1
Posted on Jun 25, 2008
Pairing mode is supposed to be activated by pressing the Volume Up and Call button simultaneously with the headset off.
I used to be able to get this to work on my headset, but it no longer will. Any solutions beyond getting a new headset?
Posted on Jun 20, 2008
6ya staff
SOURCE:
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I have htc thunderbolt when i scan it wont find my bluetooth im wondering if there compatible?
Here is a solution that might work on your HTC Thundermug. The User's Guide indicates "activate bluetooth pairing mode by pressing the Power button". It should indicate to press and hold the power button. Pressing and holding resulted in the headset being recognized within 5 seconds by the HTC Thunderbolt. This is a problem with the User's Guide.
How to Pair the Plantronics 510 Headset
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do i conect to my phone
Connecting or Pairing your Plantronics Voyager 510 Bluetooth Headset will take less than a minute. Click on the following link for instructions with photo so you know which buttons to press:
Pair Plantronics 510 Headset
Apr 23, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do you sync a plantronics 510?
allanrecht
The steps below will show you how to put your Voyager 510 into pairing mode.
To put the headset into pairing mode:
1 - Start with the headset powered on (the headset will have a blue blinking light).
2 - Press in and hold the + side of the volume button (long, thin and silver) and the Call Control Button (on the
microphone boom, oval shaped) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" (see the User Guide or call a local phone store).
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros).
Issken
Jan 25, 2010 | Plantronics 510 Voyager Headset - PLN-510...
How do i put my 510 earpiece in the pairing mode
Press and hold the switch for about 30sec ...after that it will be in pairing mode ...and enter 0000 as passkey
Oct 20, 2009 | Plantronics 510 Voyager Headset - PLN-510...
How to set it up with new phone how do i set up discoverable mode
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 510" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
Oct 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
4,807 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
