Question about Indesit W 123 Front Load Washer
Clinking noise my washer is going okay, but keeps making a clinking noise from inside when on cycle. it sounds like something is in the drum, but there isn't anything. one of the jkids has been pressing the buttons, but dont know which ones.
  • talulah Jan 27, 2008
    thanks, but this been checked and no. been told the pump may be on its way out
  • 770 Answers
After the load is done look in the unit it and hand spin the drum slowly It sounds like you have a coin or something stuck in the baffles rotate untill you can pin point it..
Posted on Jan 27, 2008
  • Gary Davd
    Gary Davd Jan 27, 2008
    OK BUT i was going to tell you how to check the pump for coins..
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
I have a Kenmore HT4 front washer and it washer is making a loud noise when it is in the spinning cycle. It sounds like the inside cycle is hitting up against something. It seem to wash okay and we...
There is only two things that I can think of 1: The bearings are going or 2: something has got under the door seal and is in between the metal drum and the plastic cover (around the drum). Could be something like a coin or even a bra wire.
Jul 28, 2011 | Kenmore Elite 45986 Front Load Washer
Noise when spinning
the bearings are going bad must be replace.
or if ou are lucky check if there is any thing inside the drum , like asmall piece of metal,,,,,
Apr 04, 2010 | Indesit W 123 Front Load Washer
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
173 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
