Question about DCS RGS-366 Professional Gas Kitchen Range
  • 2 more comments
  • TIMHUGHES1 Jan 27, 2008
  • TIMHUGHES1 Jan 28, 2008
    yes the bake function works. but i have never measured the temp.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does the BAKE function work?
  • Jeff Rockwell
    Is this to assume that the BAKE function works fine, but the BROIL does not? Also, is the oven electric or is it gas. Some gas ranges still utilize electric elements from the oven functions. This makes a difference with it comes to the repair procedures.
  • 5,911 Answers
If your BAKE function works, but the BROIL does not come on, more than likely you have a bad igniter on your broiler. The igniter is a glow bar type that comes in two basic shapes. One is round, and one is square. The round type igniter should draw between 2.7 to 3.2 amps of current to be considered good, while the square type igniter will draw 3.2 to 3.7 amps. The reason it is important to mention this is because, it is not uncommon for an igniter to still glow. and be bad. The igniter is designed to draw the required amount of current in order for the gas valve to open. Once the valve opens, you have ignition. This is a designed safety feature that prevents free-flowing gas from accumulating without ignition. An easy way to check is to remove the broil cover and turn the broiler on to see if you have any activity out of the igniter. If the igniter does not glow at all, a resistance reading can easily determine if the igniter is bad. It should read avery low resistance if good. If the igniter glows, but the gas valve never opens, take a current reading. If you can provide me with your EXACT model number (located somewhere around the oven door/lower drawer opening, or on the back of the range) I can track down a part number for. I hope this information is helpful to you.
Posted on Jan 28, 2008
5 Suggested Answers
SOURCE: Maytag MGR5775QDS oven wont heat.....
Replace the ignitor.  You will need remove the bottom plate (remove the two screws back corners).  And the disconnect the wiring from behind.  This little part will cost you approx. $100.
Posted on Feb 21, 2009
SOURCE: The whole oven and stove and broiler wont heat up
check fuses
Posted on Jun 05, 2009
  • 6 Answers
SOURCE: oven wont heat to temp its displaying no codes,
Generally speaking, if an electric oven isn't reaching the correct temperature it's usually the element or the thermostat to blame. This tips should help you diagnose what's causing the problem:
If the bake element isn't heating at all or if when it's turned on it starts tripping breakers and blowing fuses than it's probably the element that needs to be replaced. Here's our guide to how to replace a fan oven element:
If the element is heating but the oven temperature isn't accurate for where it should be than it could be the thermostat. You can test these hypothesis out with certainity by testing the continuity of both the element & the thermostat.
You should also visually ***** to make sure that there isn't any loose wiring in your cooker.
Obviously before playing around with the cooker make sure that it's unplugged and drained of residual electricy.
Posted on Mar 10, 2010
  • 15935 Answers
SOURCE: kenmore oven model#362.7122891 gas oven and broiler wont work
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Model number 3627361192 oven wont work but broiler does the oven starts but then flame goes out
replace the igniter. Even though you see it glowing, it's failing.
Jul 17, 2014 | Kenmore Ovens
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Oven burner will not light, the ignitor glows though and the broiler does work
There are 2 seperate ignitors on stoves. One for the broiler and one for the oven. Ignitors can be bad even though they glow!
Jul 20, 2011 | Ovens
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Kitchenaid oven won't fully heat
Most of the time even though the ignitor is glowing it is weak and you cannot tell it unless you do a amp check.
I have repair photos: HERE
Feb 17, 2010 | KitchenAid KGRK806PSS Gas Kitchen Range
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
DCS RGS-366 Professional Gas Kitchen Range Logo
522 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
