Question about GE WCVH6260F Front Load Washer
Washer shield broken
The washer shield of GE front load was broken. Where do I buy the parts and is this easy to replace?
Thanks,
Hoang
  • 770 Answers
The fastest place to get the part is a local parts place if you dont have anyone near check this site out www.apdepot.com there you can put in your model and brand it wil give you blown up views of your unit and pick the parts you want hey will ship them to your door i have had good luck with them .Hope this helps if so plz rate
Posted on Jan 27, 2008
6ya staff
SOURCE:
WHY DID DOOR STRIKE BREAK?
1) replace is matter easy and will resolve your problem try it.
you can buy any parts from www. repairclinic.com online.
God bless you
Jun 21, 2012 | Frigidaire ATF6000ES Front Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
GE front load washer will not spin out so the clothes come out way to wet.
Hello mtels.... when your washer will not spin out the problem is the transmission. The bad news is that this is an expensive part and an even more expensive repair. In most cases, the home owner chooses a replacement over a repair. Joe
Thanks for choosing Fixya!
Feb 03, 2011 | GE WSXH208A Front Load Washer
Ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | GE WDSR2080D Top Load Washer
How do i replace the front gasket on a ge front load washer?
When you buy parts from us here at Accurate Appliance & Parts Supply, we provide parts removal/installation instructions for our customers.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we willget the correct part out to you asap.
Thanks, Ella
Nov 17, 2009 | Washing Machines
GE top loading washer Washer wwse5200- Agititation?
it is a "trany" problem...just buy a new washer or it is a plastic cap inside that spiral part, that cap have groves...it is maybe goes bad....
GE as a brand has a lot of problem with washers, dryers, microwaves and fridges...and dishwashers so try to stay away of repairing or buying a new GE....
Sep 05, 2009 | GE WWSE5200B Top Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Sep 13, 2007 | GE WBXR2090B Top Load Washer
GE WCVH6260F Front Load Washer Logo
27 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
