Question about Pioneer DEH-P3700MP CD Player
No power to deck
I always leave my radio on, but recently the battery was removed from the car, my deck hasn't come on since. Had a friend check the fuses, they seem to be ok, what else could be the problem?
I cant hook up my i pod
Posted on Feb 24, 2008
How do I get the code to reset radio VIN JHLRD78862C035306
Check the paperwork /owners manual that came with the car. You can also try the service department of your friendly local Honda dealer.
Oct 05, 2014 | 2005 Honda CR-V 200i
Why did my radio stopped working?
double check all your connections. you can always bench test the radio with a car battery and any speaker. find your 2 hot wires and 1 ground. (1 hot wire is for memory, but with some radios it will need power also to bench check) make sure all your radio fuses are good, run a set to the speaker, then run the wires to the battery. if the radio powers up, the problem isn't the deck. this has worked for me several times.
you can skip connecting the speaker, but I prefer to make sure everything works before I reinstall.
Jul 05, 2014 | 2002 Ford F150 Regular Cab
Radio will not shut off when key is removed
Some newer cars leave the radio on after the key is removed for a preconfigured period of time. If the radio shuts off when the door is opened, this is normal activity.
If the radio is aftermarket and was recently installed, the power for the unit was pulled from an always-on source, instead of an ignition switched source. Changing the power lead to a circuit that is switched with the key will fix it.
Mar 05, 2011 | Car Audio & Video
How do you remove the Pioneeer DEH-1600 radio from the dash of a car is there a special tool or do you have to get up behind the dashboard
remove the trim plate(thin plastic strip around your deck) you will see on the center of each side slots for two thin deck keys these always come with a new deck. you you dont have them ask a friend who has recently bought a deck(any make should be fine) or go to your local best buy and ask for a set MAKE SURE YOU ASK FOR THEM FOR FREE unless the installer you asked has purchased his own universal keys they will give you them.
Aug 26, 2010 | Pioneer DEH-1600 CD Player
Bmw 318i se auto clock reset problem?
a little more information would be nice but im going to make a guess
you installed a new deck in the car, now every time you turn the car off the clock resets?
if thats correct.. the deck will have 2 power inputs, one that turns the radio off when it does not have a power signal, the other that should have a constant voltage to maintain the stereo memory, now if I'm correct you have either the 2 wired opposite to how they should be or both wired to something like the ignition wire, and it is acting like the battery has been removed every time you turn off the car, which means you need to check your stereo wiring.
if this is incorrect please leave some more info telling everyone when the clock is automatically reseting.
Aug 06, 2010 | Car Audio & Video
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
KDR606. When installed runs down battery overnight. Battery is OK. Connections as per installation instructions.New unit replacing Toyota factory radio/cassette.
disconnect the battery and measure the current flow.
measurement of more than 100ma (1/10 amp) will drain the battery.
if you have an external power amp connected,check to see that the "remote" is working correctly and not leaving the amp on.
If it only the deck by inself,take out it's inline fuse and see if the battery is still losing power.
Maybe the installer has made a mistake
Jan 13, 2010 | Car Audio & Video
2000 Audi A4 Factory Radio vs. aftermarket radio
most aftermarket units have 2 power wires 1 for the battery and 1 for a keyed hot source,what you need to do is hook both of them up to a constant (battery) power source,be sure and include an in-line fuse.
Apr 29, 2009 | 2002 Audi A4
1997 Saturn After Market Radio
The Aftermarket Stereo's have a Built in Fuse in the Power line coming from the Head Unit. Check here and let me Know.
Jan 10, 2009 | 1997 Saturn SL
Stored settings and auto eject
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Sep 25, 2007 | Dual XDM6830 CD Player
Pioneer DEH-P3700MP CD Player Logo
112 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
