Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore Refrigerator Model #596.76522500
Noticed yesterday that the refrigerator was warming up as was the freezer. We bought this unit 2.5 years ago, and it seems it only has a one year warranty. I pulled the back cover and the van is running, the compressor is warm/hot to the touch and seems to be running. Of the three or so different copper lines that are tunning out of the compressor one seems to be cool.
  • 8 more comments
  • bashley3 Jan 27, 2008
    Yes, the compressor itself is warm and the line that runs to the coil under the unit is also warm.
    Alright, I checked the coil from the front and it was indeed pretty dusty. I completely cleaned the coil and am now waiting to see if this helps bring then temp of the refrigerator down. The freezer is holding right now at 0 but there is a small amount of frost on the very back of the freezer, not what I would call an unusual amount.
    The refrigerator is room temp. Should this help now or is has this possibly caused a bigger issue since the coils were so dirty?
    Thank you for all your help so far!!!!
    The fan was running yes. On this model how do I check to see if the fan in the freezer is running? The back of this fridge is solid and I could only gain access to the bottom back and front...
    I cant seem to locate the fan for the fridge and its still at about 74 degrees with the freezer holding its own...My guess is the fan isnt running since we should have seen a drop in the fridge by now....
    Okay, i was able to remove the small back cover in the freezer and got to the fan...it wasn't moving...i gave it a flick with my finger and it started (and continued) spinning...
  • bashley3 Jan 28, 2008
    I'm not sure if i fixed it as i haven't seen any temperature change yet and the fan does seem to be moving as fast as one would think...i could be wrong tho. Is it normal that i can stop the fan with my finger and it wont start moving on its own again? If i flick it with my finger it will move...but stops easily if i touch it...
    Thanks you have been a great help!
  • Anonymous Feb 25, 2008
    fridge and freezer are warm wont get cold.We checked the fan in back and vaccumed out the bottom.
  • helpmyfrigde Feb 25, 2008
    We have this fridge and it won't get cold on either side . I've checked the fan on back as well as the fan in the freezer and both are working. None of the cooper tubes in back are cold to the touch and I cleaned thye coils in the front. What more do you think I should do? If you can help I would really be inappreciative.
  • Anonymous Jun 16, 2008
    Yes< I got the same problem.Please advise.
    Thanks,
    Ko Ko
Where is the motor,Evaporator fan locate at?
Thanks,
Ko Ko
Posted on Jun 16, 2008
  • 770 Answers
Let me pul the book on this and get back to you BTW is one of the lines (the one going to the coil under the unit) really warm??
Posted on Jan 27, 2008
  • 3 more comments
  • Gary Davd
    Gary Davd Jan 27, 2008
    I have the manual here a couple more thing to check is 1st the coil you felt the line to is it clean?? remove the front kick plate and look in with a flashlight.. If it is pretty clean then the next step is to check in the freezer on the back wall is there any frost build up in just one area?/let me know
  • Gary Davd
    No what happens when the coils get dirty it blocks the air flow to cool the condenser coil and compresser thus cutting down on the cooling effecy. the compressor has an overload that will shut it down if it gets too hot then auto reset to start back up you said the condenser fan was running right??? Well this pulls the air and dog hair and dust from your house across the coil to remove the heat it has transferd from inside the refrigerator cools the coil and goes out that vent holes in the back panel.. One other thing to check is the fan inside the freezer working?? this is needed to blow the cold air into the refrigerator section
  • Gary Davd
    There is only one fan and it is mounted above the coils (were you see the frost) you will need to remove the back wall in the freezer you can feel in the top back left corner of the refrig. section with the freezer door closed to see how the air flow is you may have to remove a cover or reach under it feel the air flow.. If the fan is running and the cooil is clean and no large ice buid up give it some time it should start to cool down
  • Gary Davd
    Gary Davd Jan 28, 2008
    you Fixed it !!! the fan must have been stuck keep an eye on it ove the next day or so it may need replaced... this usally happens if a fridg. has been sitting and off for awhile. If you dont need my help anymore please rate me.
  • Gary Davd
    If you do need to replace it the part # is 12002744 it is $35.99 at www.sears.com click under parts tab OR it is $29.91 at www.apdepot.com just enter part nmber or if you have a local parts place call with the part # tell them it is a Whirlpool part Number.. Good Luck
What is weight of kenmore freezer model 25320402002?
For 5-foot-tall units: A 32 refrigerator or freezer weighs about 150 pounds and takes up 38 cubic feet. A 32-inch refrigerator or freezer weighs about 200 pounds and takes up 44 cubic feet.
Jul 05, 2018 | Kenmore Freezers
Freezer fine but fridge warm
The fan seems to be out looks like you need a new fan motor for freezer component
Nov 14, 2013 | GE PDS22SIS Bottom Freezer Refrigerator
I bought a may tag fridge 2 years ago model mb1956kes every 15 minutes my frige makes a ticking sound the sound last for 10 second
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Maytag Refrigerators
My LG refrigerator, model LMX25981ST, the refrigerator and the freezer just stopped keeping everything cold. Left to go to town yesterday and all was well. I came home in the evening and everything in...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 17, 2011 | Refrigerators
I have a refrigerator that is about 12 years old. It was working fine, unntil about a week ago, everything got warm in the freezer and now the fridge part is cool. Any ideas on what could be wrong?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 04, 2010 | Kenmore 64802 Top Freezer Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer is not cooling properly
Look inside the fresh food section behind and inside the control panel for a defrost timer and circuit board. Let me know when and what you find. Please unplug first, Thanks, Sea Breeze
E. Cold Control & Defrost Timer/Automatic Defrost
Control
These parts can produce a snapping or clicking sound
when turning the refrigerator on and off. The timer also
produces sounds similar to an electric clock.
Mar 27, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
581 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
