Question about Elektra Nivola Coffee Maker, Espresso Machine
Steam In my Nivola only steam comes out from the group and blows up the coffee pods.
I suggest your thermostat is defect. I had the same problem, ordered a new thermostat changed it - bingo!
Posted on Oct 28, 2008
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
How to steam milk
Hi
I am sure there is a spout that blows steam into cold milk and make the milk warm. Free User Manuals and Owners Guides ManualsOnline com If you haven't got your user,annual handy, look for it there. Enjoy your coffee, kolbrun
Jan 28, 2015 | Orphan Espresso Olympia Cremina Espresso...
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
How do you use model 40715 hamilton beach espresso machine? i couldnt get the loose grinds to work so i bought espresso pods and now i dont know how long to wait for it to drip or if im even doing it...
I have this machine and have used it for about a year. Most important is use fresh beans within 15 days of roast, and within 15 minutes of grinding. You cannot get good results from this machine using pre ground coffee, or pods. Second, this machine is terrible with temperature stability. When warmed up it will usually be way too hot. Wait for the machine to warm up (light will come on). Open the steam valve, run the brew pump for 5 to 10 seconds into your cup and turn it off. Shut the steam valve, wait for the light to come back on. Immediately hit the brew button. This procedure will do a nice cooling flush and hit more towards the right temp.
Third, the pressurized basket that comes with this machine just dosen't do the job right. Replace it with a Mr. Coffee double basket, non pressurized and you will see immediately better results.
Last, the screeching steam wand. This machine will give wet steam, all the time. After pulling the shot, hit the steam switch and wait 20-30 seconds, then open the steam valve full to purge water out of the wand. Close the valve, then go to steaming your milk. There is a place about 1/4 inch below the surface that you'll hear only a chhh-chhh sound. Wand too deep, it will screech and wake the neighbors. Too shallow and you'll get sudsy big bubbles. Just find that sweet spot and surf there till you're at 140-150 degrees then turn the valve off. Good luck.
Jan 04, 2011 | Hamilton Beach Coffee Makers & Espresso...
Safety valve cn10 keeps activating about 10 seconds after switch on. any ideas anyone. stafco markus 2 group semi auto
Try this open the steam wand and leave on when turning the machine on, when valve stats hissing with steam close. If that works then the vent valve needs to be replaced, If it blows out hot steam from valve then the pressure stat is not operating properly.
Jun 22, 2010 | EXPOBAR Office Control Espresso Machine
When trying to steam milk, very hot water comes out of the steamer arm and curdles the milks. Additionally no hot water comes out of the opening for the coffee, so no espresso is made. This started...
It seems that your problem is the one mention second that no water come out for coffee. So every time you try to make coffee the boiler is overflow and you have more water from steam tap.
So you have to clean the coffee shower on coffee group head since this might be blocked by dry coffee. Also the coffee solenoid valve could be also blocked from dry coffee and it can be removed and cleaned with a wire brush. It can be also be damage and most posible the solenoid coil burn out so you might need a new solenoid. So I beleive if you solve the coffee group blocked problem then you might have solve also the steam problem,
Good Luck
Remeber to vote for this answer.
Feb 23, 2010 | Krups Cappuccino/Espresso Maker -...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Elektra Nivola Coffee Maker, Espresso Machine Logo
99 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
Shehu Pro
Shehu Pro
vilhj
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
