Question about Lands Phones
Philips SE 435 Handset beeping intermittently
Hi
One of the handsets is beeping intermittently for no apparent reason. The batteries seem to be fully charged and i can't find anything else
  • 1 more comment
  • James Biddle Feb 27, 2008
    every night at around 10:30 base unit starts beeping and continues for about 3 minutes then stops!!!!!
  • aescholz Feb 19, 2009
    I have just returned from a holiday,and found a message with 7 new calls displayed on my base phone,I cant read,listen,nor remove this message signal,with its flashing light,can you help.???
  • Anonymous Mar 21, 2014
    I cannot access any menu, phone calls it seems the screen is frozen but if I take the battery out and replace it, it goes to "searching" and then goes back to "welcome"!
  • 3 Answers
I had this problem, solved it by going to the advanced settings menu and resetting the handset. I guess the handset got out of sync with the base station after I deleted messages... once reset it was fine.
Posted on Sep 15, 2008
Sounds like your alarm or reminder on the handset has been activated to go off at this time every night, look up in the instructions for how to deactivate it.
Posted on Jun 15, 2008
Just a thought....is the alarm set to go off at 10:30???
Posted on Jun 02, 2008
Message with light flashing says "1 new call" but there isn't a message and light annoyingly won't cancel-how can we stop it flashing and prevent recurrence? thanks
Posted on Aug 01, 2008
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
Philips cordless phone se 455
CANON IR2520 ERROR E000000
Nov 11, 2013 | Lands Phones
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
The handset reads "Initial". Everything
The problem is with the base unit (charger) u can use the handset with another unit
Nov 30, 2010 | Philips CD-150
Handset reads "searching"
The reason the handset says "Searching" is because it can not find its Base Station. What handset works with a notebook? I had not heard of such a thing.
Sep 15, 2009 | Philips VOIP3211S/05 IP Wireless Phone
Handset 2 show unavailable
hello
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Lands Phones Logo
1,184 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
