Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 leaking from the drawer
Can anyone help me, i have a hotpoint wd62 washer dryer and everytime i turn it on to do a cycle the water spills out from the drawer for about 30seconds then the machine completes the cycle with no problems at all.
Any help greatly appreciated, im going mad not being able to wash all my baby clothes.
I took the rinse aid divider out, ok so far,. always put detergent in drum not drawer that seemed to help.
Posted on Nov 21, 2009
I read the "water pressure too high comment" and tried opening a cold water tap to reduce the pressure to the machine - it worked! (so far)
Posted on Jan 31, 2009
Had the same problem inlet water pressure was too high. K7
Posted on Feb 11, 2008
    Master:
  • 619 Answers
Hi, check the electrict valve winding busted hot and cold.
Posted on Jan 27, 2008
6ya staff
SOURCE:
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint washing machine leaks at soap drawer
check for any in drawer. if not relevel unit. make front a little higher than rear
Jun 22, 2009 | Hotpoint WD62 Front Load Washer / Dryer
WD62 DOES NOT CYCLE THROUGH ITS PROGRAMME
hi, this model is notorious for programme faults and i would suggest you change the controller, hope this helps
Feb 09, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint W/D valve problem
yes change inserts around leave top off test and watch. red is for hot water black for cold
Nov 20, 2007 | Hotpoint WD62 Front Load Washer / Dryer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
244 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
